I've done a search in this forum and the super duty forum and i can't seem to find a definitive answer.
I have an 05 350 PSD torqueshift and i want to do a tranny flush tmrw, is Mercon SP the correct fluid? Is it 18 qts for a full flush? Also, is it necessary to do a filter swap? If so, does anyone know the filter number ?
18 quarts of Mercon SP is correct though it really depends on how much fluid you can get out of the transmission. Good dealer service departments use a heated flush machine to get all of the old fluid out. There's also info in the 6.0 Tech thread at the top of this forum with instructions on DIY. Here's a link: https://www.ford-trucks.com/forums/3...ch-folder.html
The external filter in the aluminum canister is an FT-145. They are available thru site sponsor Diesel filters online for a reasonable price. The internal unit is really a fine screen and not a filter, per se. Those are changed at 60K intervals. I change the FT-145 on mine every 10K because I tow.
If you have an impact wrench handy that is the best way to loosen the aluminum canister to remove/replace that filter.
You can get the external filter at any auto parts store for $20, I get them at O'Rielly's here in Houston. Here is a pic of the canaster and it is on the front right side of the radiator. Motocraft #FT-145 $19.99, WIX 57702 $19.99<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Mine came off with just a soclet wrench but some have had troubles.
