Transmission Flush / purge or Pan Fluid drop and fill?
Ok, I got many good answer on which fluid to use in the XMSN, it will be Mercon SP if I can find some or Mercon LV.
Now, I am debating if I should go to the Dealer, $340 without filter change.
Dealer tell me they flush the Transmission using a flush and purge machine. Do you know if their procedure is much better than just dropping the fluid from the pan and refill?
The "Flush" machines connect to the cooling lines and "trade" fluid, but does it realy flushes or Nothing gets "flushed" other than your wallet. Does it change the fluid trapped in the torque converter? On top, they ignore the filter.
Not sure if the machine is hot fluid, one dealer tell me they do it with engine warmed up, do they realy?
A hot flush will change all of the fluid in the transmission and the torque converter. If they are telling you they do it with the engine warmed up they don't know enough to know they must have a heated flush machine to do this. Without a heated flush machine they are just flushing your wallet.
I have never had my tranny flushed. Every 20K or so I drop the pan, change the internal and external filters and top off. Never seen and degredation in the color or odor of the fluid and no tranny problem either. Draining the pan also allows the cleaning of the magnetic drain plug. I would save the money.
Bryan
Bryan
Bryan
Bryan
Happens all the time.
Josh
The manual calls for 211-00018 or 199-00010 machine if you use the automated equipment procedure, I could not find these machines number on the Web so no way to say if it is a hot or normal machine. They also describe the procedure for fluid drain and refill using the drain plug. There is no "prefered or recommended " method, so I guess the Dealers can use both without being scare of a problem with the trany, so can we I would say.
In the automated procedure, they say to use a "suitable flush and fill machine", nothing about using a hot flush or warming up the trany, so the tech could not care less if it is hot or not. They even argue a little when I ask to replace the filter, they say there is no need.
Yes I did.It took awhile to explain what a "Hot flush" was to the service writers.After I found a dealer that knew what it was I went to them.They were the only ones out of the seven I called in the area.Most said "Oh yea we do the flush".So I asked how they did it."We just drop the pan and drain it" Thanks,I'll pass...I don't let anybody touch my truck,So I asked the tech if he minded I watch.They didn't have any problem with it.Athough they said it was an unusual request and didn't normally do that but they were cool about it.I got to see the machine and how they hook up the lines.He probably ran the flush for ten mins or so.He also said that the fluid came out of the machine at 130*.
Probably had some Mercon V mixed in the system as well.
Josh
