help
Old Mar 29, 2012 | 07:32 AM
dorton's Avatar
dorton
help
i have a 94 ford f150. when starting out in drive it goes stright to drive it misses 1 2 3. there is no up shift or down shift.
Old Mar 29, 2012 | 07:34 AM
nstueve's Avatar
nstueve
need to know what tranny you have to be any help. get the "Trans" code off your door pillar code if you don't know and we can tell you what you have
Old Mar 29, 2012 | 09:15 AM
dorton's Avatar
dorton
my trans is e thats what it reads on my door my bolts on the bottom of the trans i counted 20 of them. heres what happen i ran off the road, hit some trees and a large stump stopped me but it stop me by hitting the cross bar on my trans when i got pulled out and back on the road went to take off and thats when it started in over drive no down or up shifting just over drive ive done bout ever thing i can think of u can put it in 2nd to shift but its like its stuck in od
Old Mar 29, 2012 | 09:20 AM
dorton's Avatar
dorton
e is my trans
Old Mar 29, 2012 | 09:21 AM
dorton's Avatar
dorton
e
my trans is e
Old Mar 29, 2012 | 09:30 AM
dorton's Avatar
dorton
trans is e
Old Mar 29, 2012 | 09:32 AM
dorton's Avatar
dorton
trans is e
<!-- / message -->
<!-- controls -->
Old Mar 29, 2012 | 09:36 AM
GNR22's Avatar
GNR22
You don't need to post the same thing 5 times...
The transmission E code is the E40D transmission. Which is all computer controlled. Check engine light come on? I would imagine that it tripped some kind of code if your tranny won't shift.
Old Mar 29, 2012 | 10:38 AM
dorton's Avatar
dorton
no check engine light didnt come on. ive takeing the batter cables off to reset the compter still same thing. the cross mem bar on trans did get bent back alot and the heat sheld on the trans got ripet off. i pull off the wires that go to the right side of the trans and still the same thing i unplug the speed sencer on the rear end and still same thing i have the same truck but its the eb truck and when the speed sencer on it went out i could drive untill it went into drive and they was nething like it was in neutrel. but when i pulled it from this one this the same as if i didnt pull it. i can drive it just have to put it in 2nd to take off and when i put it in 1 its like its in 2nd. it drives ok just no down or up shift. my other 94 has no over drive its there cause i can be doing 55 or 60 and go from d to n and back to d and theres over drive but only for a few secs and back out of over drive and have to take it out of over drive or its like it goes to neutrel. one truck is stuck in over drive and one of my drive wont go into over drive boy o boy want to to
Old Mar 29, 2012 | 11:27 AM
dorton's Avatar
dorton
no check e light didnt come on
Old Mar 29, 2012 | 11:41 AM
GNR22's Avatar
GNR22
Like I said, you don't need to say the same thing more than once...
It almost sounds like it's in limp mode. Where something is drastically wrong, yet it will let you limp it to a destination, which in your case should be a repair shop to straighten out everything you messed up. If you ripped off the shield, you probably ripped off some wiring or something.
Old Mar 29, 2012 | 01:07 PM
rla2005's Avatar
rla2005
I think the transmission will start off in 4th gear if the connections to the solenoid block are open. The solenoid block connector is on the passenger side of the transmission. Even though you may not have a Check Engine Light On there will probably be some stored codes. Especially if the connection(s) to the solenoid block are fubarred. Those codes may lead you to the root cause.
Old Mar 30, 2012 | 02:36 PM
dorton's Avatar
dorton
i can unplug it and same thing like i didnt even unplug it
Old Mar 30, 2012 | 03:41 PM
rla2005's Avatar
rla2005
That is exactly my point. If it acts the same plugged in or not plugged in then you more than likely have a wiring issue.
Old Mar 30, 2012 | 05:56 PM
dorton's Avatar
dorton
think it has to be inside trans cause i took the wireing harnes from my other 94 the one that wont go in to over drive lol and still the same thing
