Oil Pump Replacement
Old Nov 13, 2008 | 02:24 PM
DILLIGAF13's Avatar
DILLIGAF13
My Question Is Can The Oil Pump On An 89 F250 W/ 460 Be Replaced Wihout Jacking Up The Engine? I Replaced The Oil Pump On My 79 F250 Without Fully Removing The Pan, I Just Worked Around It. It Was A Bit Of A Pain To Do But Engine Lifts Ain't Free.
Old Nov 13, 2008 | 02:48 PM
alz's Avatar
alz
If you've got a jack it's doable. I removed/replaced the pan and pump on a 5.0 and a 5.8. Lift engine by using a 2x6 under the harmonic balancer and jack it up. Obviously you need to loosen mounts and such. You should be able to replace the oil pump once you get a little clearance between the block and pan.
COMTNMAN
Aug 3, 2014 10:45 AM
klr650goldwing
Mar 31, 2010 05:17 PM
bc2sv
Aug 28, 2009 05:40 PM
followwell
Nov 16, 2008 09:19 PM
trakker
Aerostar
13
Jan 3, 2003 08:30 AM
