O/D light flashing
Old Nov 13, 2008 | 11:26 AM
Ponyboychris's Avatar
Ponyboychris
Are the fluids good? When's the last time it was changed - filter too?
Old Nov 13, 2008 | 11:51 AM
pwstroker69's Avatar
pwstroker69
Should be, I haven't checked in a while but did a fluid change myself with the last oil change (about 2 years ago, Oops).
D.
Old Nov 13, 2008 | 11:54 AM
Ponyboychris
D.
Wow, two years between engine oil changes??? not a very big island eh?
Old Nov 13, 2008 | 12:28 PM
pwstroker69
Actually, it's been quite a bit longer.....look for 'Basic Oil Change Question' thread recently. The truck was due a change before I moved, then it sat a year and then I shipped it down and couldn't find the oil I like to use. So until Last week, she probably had 3 year old oil coarsing thru her veins......se's very happy with me now, apart from this light thing yesterday. Ran it twice today to drop and pickup my daughter at pre-school, no light and no probs with the speedometer.
David.
Old Nov 13, 2008 | 12:56 PM
Ponyboychris
Your truck is a good candidate for Sythn oil so you don't have to hassle with frequent changes. LOL
Back to the original topic. It still should have the code stored in the PCM if you can find the means to retrieve it.
Old Nov 17, 2008 | 11:56 AM
aklim's Avatar
aklim
Originally Posted by Ponyboychris
Is your speedo acting erratically also? If yes, then your VSS (vehicle speed sensor) on top of the rear pumpkin is failing. Easy and cheap fix. If not, then you need someone to pull the codes that are stored for a possible tranny problem.
I thought the VSS was the sensor on the output shaft?
david moore
Jan 18, 2013 06:07 PM
phxcpa
Oct 21, 2012 02:15 PM
Woodlums
Nov 29, 2006 09:11 PM
3003David
Aerostar
36
Jul 18, 2004 12:48 PM
david b
May 8, 2001 06:30 PM
