got a wierd rough running condition when first starting
when i start the truck in the morning or when coming home from work it fires up just fine then i put it in drive and after about 30 seconds the check engine light comes on and the idle drops down to mabye 200 rpm and i have to put it in neutral to keep it running. this will happen for 30 seconds to a minute or if i just put it in drive it is fine. after waiting 30 seconds or putting it in drive it runs fine, the check engine light goes off, and all is fine. won't do it again till it sits for hours again. this has just started in the past 2 days and i haven't changed naything or done anything to the truck.
sounds like the high pressure oil res. may be draining back when you let it sit for awhile? you need to get a scanner on it and figure out what code it is setting for the CEL and let us know what code it throws. thats where you need to start. check it with a scanner
i have no way to check the cel. i don't have a scanner and it goes away too fast for me to get it to a shop.
To get the stored codes you will need a good reader. The ones at Autozone etc. won't pull stored codes. A good shop will have one but they will charge you.
sorry i haven't updated this yet. do melted or burnt connectors and so far i haven't had time to get to a shop to check the cel. but on the bright side it hasn't done it in 3 days. go figure still slightly troubling though not knowing..
