Oil Pan Rust - Bad...
Old Nov 12, 2008 | 02:21 PM
HKusp's Avatar
HKusp
Now imagine this thing a flat black and flaking rust mess before and this is the after. I will see if I have a decent shot of the front of the truck with the mount showing what it looked like before.
Old Nov 12, 2008 | 02:26 PM
HKusp's Avatar
HKusp
You can sort of make it out in this picture. To tell you the truth, I was usually trying to avoid showing it in pictures because of how bad the thing looked before.
Old Nov 12, 2008 | 02:30 PM
Ponyboychris's Avatar
Ponyboychris
Jason, that does look good.
Old Nov 12, 2008 | 02:41 PM
1996pwrstrk's Avatar
1996pwrstrk
When I rebuilt my 1980 Bronco in 1997 ( it was in Oh. all its life: read very rusty ) I used POR15 on the frame and under whole vehicle . I drove it down here and sold it about 5 yrs ago but I saw it on a used car lot this summer and the underneath still looked good and it had been doing some heavyduty four wheel'n. POR 15 is tough stuff.
Old Nov 12, 2008 | 03:30 PM
HKusp's Avatar
HKusp
Agreed. When I just checked the kit, I had taken a piece of saran wrap and put it on the top of the unused portion before closing the lid, per the instructions, and the little bit that was in the grooves of the can oozed over and hardened. That stuff is very very hard. If I hadn't put that saran wrap on it, the rest of that can would be a paperweight now, I'm sure.
Old Nov 12, 2008 | 04:18 PM
Kwikkordead's Avatar
Kwikkordead
I recommend getting the black coat.
POR 15 by itself is not UV protected and it will fade eventually.
I did my winch mount with just POR 15 and now I have to do it again because the sun cooked the paint. It only took a year to dull the finish.
Old Nov 12, 2008 | 04:47 PM
HKusp's Avatar
HKusp
Good to know Dan
Old Nov 12, 2008 | 04:52 PM
1996pwrstrk
Yes your right about that Dan but on a oil pan I think he will be fine with out a top coat don't you , unless he leaves it parked wrong side up for a while.
Old Nov 12, 2008 | 06:12 PM
JMac444's Avatar
JMac444
Ive done many pans with just the por 15. The blackcoat isnt really nessary since the sun does come into direct contact with your oil pan, all the blackcoate does is top coat the por 15 so it doesnt fade.All the pans ive done still have a nice shine and look just like the day i did them. Just my 2 cents.
Old Nov 26, 2008 | 01:45 AM
Neil64's Avatar
Neil64
Thickness
How thick is this stuff and a black topcoat? I am thinking about doing my Meyer Snowplow mount and the tube frame that slides into it. It is a snug fit so I don't want to waste time and money if assembling is just going to remove the POR 15.
Also, can it be bought locally or do you have to get it on-line?
Thanks...
Neil
Old Nov 26, 2008 | 07:12 AM
Kwikkordead
I suppose so.
But if you want the ultimate protection, that Top Coat is like armor.
It is a two part chemically cured paint that turns into something like cured ceramic. ROCK hard.
Old Nov 26, 2008 | 11:54 AM
Neil64's Avatar
Neil64
Thickness
So do you think it will be too thick to work in this application, with or without the topcoat?
Thanks...
Neil
Old Nov 26, 2008 | 12:06 PM
  #28
1996pwrstrk
Thanks...
Neil
It is pretty thick stuff but I think you can thin it with reducer . You can check with a POR15 paint rep they will be able to tell you what to use and how to apply it. If you do use it MAKE SURE THE PAINT IS COMPLETELY DRY before sliding the pieces together or you will never get them apart.
Old Nov 29, 2008 | 06:27 AM
  #29
Neil64's Avatar
Neil64
Drying Time
How long does it take for this stuff to dry? Is everything applied with a brush? If so, I can paint everything post install.
Thanks...
Neil
benwantland
Oct 6, 2008 04:55 PM
Budkole
Aug 13, 2005 05:58 PM
92 Red F150
28
Jul 30, 2004 04:46 PM
MickeyP
Paint & Bodywork
May 12, 2003 08:42 PM
ljmieyal
Apr 19, 2000 07:51 AM
