squeaky shock
Old Nov 11, 2008 | 07:02 PM
87wreckerman's Avatar
87wreckerman
squeaky shock
anyway to stop a shock from squeaking?? my pass side front shock is squeaking evrytime i go over a bump, i know the proper way to fix would be replace it but it doesnt feel bad really, just squeaks. any good oils out there that should stop it for a lil while?? if i could manage to get the oil on the shaft of the shock, thinking wd40 with the straw hooked up?
Old Nov 11, 2008 | 07:13 PM
Gevans17's Avatar
Gevans17
oiling a squeaky shock
been there ..done that..doesnt work for long.
Old Nov 11, 2008 | 07:27 PM
87wreckerman
lol, yeah i figure it prolly wouldnt. would a certain oil be better then another? like a white lithium over wd40 or...
Old Nov 11, 2008 | 08:19 PM
madsonp's Avatar
madsonp
Are you sure it's the shock ? Could also be worn out bushings.
Old Nov 11, 2008 | 09:09 PM
87wreckerman
ive went over the whole front susp and even replaced the from sway bar bushings, plus sprayed evrything down with white lit grease. still squeaks?? only thing left really is the shocks, all other bushings look good.
Old Nov 12, 2008 | 05:13 AM
c_hohensee's Avatar
c_hohensee
How are your ball joints? The lowers can cause a god-awful sqeeking noise.
Old Nov 12, 2008 | 07:02 AM
87wreckerman
they seem ok. ive lifted the front end off the ground and theres no side to side or up and down movement in the wheel. however i did notice sitting in the driveway if i turn the wheel side to side it squeaks then also? probably is the ball joint, ill see if i can try and get some grease through the boot to quiet it up for a lil bit
Old Nov 12, 2008 | 10:10 AM
87wreckerman
yep its the lower balljoint, poked a hole in the boot and sprayed some white lit grease and squeaking stopped
treverd
15
Sep 12, 2016 03:09 AM
robinsonpowerstroke
49
Apr 17, 2013 09:29 AM
mikecox1
Sep 19, 2008 12:49 PM
goatdriver
2004 - 2008 F150
Jun 3, 2007 07:47 PM
sspears
Aug 19, 2000 12:59 PM
