rear axle fluid
Old Nov 11, 2008 | 12:13 AM
dsljay's Avatar
dsljay
rear axle fluid
When I checked the rear axle on my wifes 2002 Mountaineer the fluid was grayist. Is this normal or is because it's synthetic 75w-140 fluid? The reason that I checked the rear was because it seems to be getting louder.
Also, how can I tell if this car has a standard or a limited slip rear? I see that it will take a friction modifier if it has a limited slip rear.
Thanks, Jay
Old Nov 11, 2008 | 08:26 AM
steve(ill)'s Avatar
steve(ill)
the grey is water in the oil. you should change with 75-140 FULL synthetic oil. synthetic sticks better to the gears and will change the "noise" pitch. a also tried the addative even tho i dont have limit slip. that stuff has friction modifiers that also make the oil "stick". and will change the noise level in the gear mesh. try it , it works. also if you have an ABS light from time to time, that is the dirty oil sticking on the pickup. pull it out of the top of the pumpkin and clean off the end.
Old Nov 12, 2008 | 12:11 AM
dsljay's Avatar
dsljay
Thanks, Steve. Did you have to buy the friction modifier from the dealer or is it availible at a parts stores?
Old Nov 12, 2008 | 02:26 PM
expo1's Avatar
expo1
you can buy friction modifier in the parts store blue container 4-5 dollars. just make sure it's for FORD
Old Nov 12, 2008 | 08:52 PM
steve(ill)'s Avatar
steve(ill)
i got a 7 oz tube for $7. at auto zone. use the whole thing. dont believe that 4 oz (Ford) is enough.
Old Nov 12, 2008 | 11:58 PM
dsljay's Avatar
dsljay
Thanks, guys. I'd still like to know if I do have a limiled slip rear. Maybe I'll call the dealer.
Thanks again for the advice, Jay
Old Nov 13, 2008 | 09:47 PM
steve(ill)'s Avatar
steve(ill)
look at the axle code on the drivers door post.
Ford Explorer Gear Ratio's
Old Nov 14, 2008 | 12:36 AM
dsljay's Avatar
dsljay
OK Steve. How did you find that info? I have a number 45 axle and a V trany. The axle is a 3.55c.
Do you know what the SPR means on that lable? I have a KE.????
Do you have a full vin decoder?
Thanks again for the info, Jay
Old Nov 15, 2008 | 08:13 PM
Mark250's Avatar
Mark250
Look at your axle tag. An L in the ratio means limited slip. Example: 3L55
Old Nov 15, 2008 | 09:40 PM
dsljay's Avatar
dsljay
Thanks, Mark.
Old Nov 16, 2008 | 08:29 AM
steve(ill)'s Avatar
steve(ill)
read the second post here
https://www.ford-trucks.com/forums/7...nd-the-es.html
Camper Special Gene
Apr 16, 2014 05:05 PM
micguyver
Nov 11, 2009 09:00 PM
brian931
1983 - 2012 Ranger & B-Series
Apr 8, 2009 07:16 AM
rsjohnsn
Aug 30, 2006 01:12 PM
coachhomer
Dec 7, 2002 01:15 PM
