Sponsored by: Kumho
Rust Issues: Radius Arms
Old Sep 1, 2002 | 03:04 AM
Boss_358's Avatar
Boss_358
I'm in the process of overhauling the whole front suspension on our 82 Bronco. I pulled the drivers side radius arm out to replace the bushings and found that the factory rubber bushing had rotted and that section of the radius arm had as well. Now the new bushings fit on real loose. I measured the right side which looked ok and was getting around .875 on average. The left side came out at .636 at the lowest point I could find. It tapers down to that diameter as it gets closer to the threads. I was wondering if anyone else has seen this or has had to deal with it. I got a price on a used one at $45.00 but am not sure if that is good or not. I have no idea what these cost from Ford and probably do not want to know. If anyone has any ideas or sources on where I might be able to get a decent one that would be great. I need to get this truck fixed asap and I just do not feel safe running that old radius arm the way it is rotting away.
Thanks,
Derick
Old Sep 3, 2002 | 05:03 PM
AZ4x4f150's Avatar
AZ4x4f150
Old Sep 4, 2002 | 09:57 AM
marriedguy1's Avatar
marriedguy1
I've got the radius arms off of my 94 Bronco in my garage if you are interested in one or both of them. Let me know what part of the country you are in.
reem98
15
Nov 15, 2023 06:08 AM
frederic
Jul 16, 2021 09:01 PM
DSN46
Jan 26, 2017 07:08 AM
fearnoone24
Feb 11, 2013 08:53 PM
redneckbitch
Dec 30, 2006 01:52 PM
