Radius Arm Bushings
Old Dec 30, 2006 | 09:13 AM
redneckbitch's Avatar
redneckbitch
Radius Arm Bushings
I saw a post on here about shimming the radius arm bushings on a Ford explorer. can anyone help me out with that info.
Old Dec 30, 2006 | 09:27 AM
JSchilberg's Avatar
JSchilberg
Have you tried the search function?
Old Dec 30, 2006 | 11:18 AM
sjwoody's Avatar
sjwoody
I think the idea was to replace the bushings, and during the installation add a thick washer to the backside of both the forward and aft bushing on each arm. This serves to tighten the joint, and reduce the amount of movement allowed. I suppose you could just add a washer (or shim) to the backside of the aft half of the bushing, but I suspect if you're having a problem, the real issue lies in the forward half where the rubber or neoprene portion of the bushing passes through the radius arm bracket. It has worn, or deteriorated from the heat of the exhaust, and adding a shim to the aft (the easy side) won't really help you at all.
Old Dec 30, 2006 | 12:50 PM
MisterCMK's Avatar
MisterCMK
Just replace the bushings and see where that gets you. I used a set of poly bushings with plenty of grease to keep them quiet. Rather than unbolting the bracket and removing the rivets, I used a come-a-long to pull the front axle forward. It took me an hour and a half per side.
Old Dec 30, 2006 | 01:52 PM
sjwoody's Avatar
sjwoody
I used the come-a-long too. I didn't feel comfortable drilling out the rivets on the frame. If you use the come-a-long, make sure the shock and spring are removed so the I-beam can drop low enough to allow enough movement. The first one I did took about 4 hours while I "learned". The other side took about an hour and a half.
