Sponsored by: Real Truck
wheel shake
Old Nov 10, 2008 | 04:22 PM
richcraft's Avatar
richcraft
wheel shake
ok guys I have a 2008 f-250 crew cab 4x4 with a 6" lift and 37s. when I get up to about 70 mph and hit any kind of bump in the road I get a violent wheel shake that wont stop untill I get back down to about 45 mph.( a couple of you have probably almost rear ended me ) anyway I know your thinking it probably has to do with the lift but I have had it back twice to be checked and they say allienment ballance everything ok. So Im talking to a buddy and he says his new ford work truck dose exactly the same thing.Has anyone had or is haveing similar problems. Thanks in advance for your imput
Old Nov 10, 2008 | 04:27 PM
DCSpecial's Avatar
DCSpecial
Do you have the stock stabilizer on it?
What kind of lift?
Do you by chance know what your caster setting is?
Trac bar and trac bar bracket properly torqued to spec?
Old Nov 11, 2008 | 08:55 AM
richcraft's Avatar
richcraft
What kind of lift?
I purchased this truck new from ford with a fabteck lift from 4 wheel parts already on it. It has duel steering stabilizers. You mention caster a friend of mine mentioned it to.Do you have any suggestions were I can have this checked?
Old Nov 11, 2008 | 10:01 AM
DCSpecial's Avatar
DCSpecial
Was the stock stabilizer removed when they installed the duals?
Caster would be checked during alignment.
As for what caster is:
Wheel Alignment A Short Course
Old Nov 11, 2008 | 10:36 AM
richcraft's Avatar
richcraft
DCS yes the stock stabalizer was removed the new ones have fabteck dimpled in on them. Back to caster is there a way to check this myself. I noticed that there is an ajustmant both top and bottom on the raidios arms
Old Nov 11, 2008 | 11:29 AM
12ozd's Avatar
12ozd
Not unless you have alignment plates and a wheel gauge.
( Usually not a DIY check )
Caster is checked during a F.E.A.
The alignment tech. should check / adjust - caster, camber , toe at a minimum.
I have seen steering shocks do exactly what you describe.
With the lift and tires you have, they will wear quickly.
Old Nov 11, 2008 | 02:35 PM
richcraft's Avatar
richcraft
I called 4 wheel parts and made an apointment to have everything checked again.
Old Nov 11, 2008 | 03:02 PM
DCSpecial's Avatar
DCSpecial
Especially have them check that the trac bar and trac bar bracket are torqued to spec.
Along with checking the caster.
Old Nov 11, 2008 | 04:32 PM
richcraft's Avatar
richcraft
will do thanks for the advise and ill keep you posted
Old Nov 13, 2008 | 03:10 PM
richcraft's Avatar
richcraft
Ok so I roll into 4 wheel parts they glance under the truck and asure me its the track bar bushing that they have had a few come in with these bad on brand new trucks.So I have to decide what to do because neither they or ford will pay. The guy says 105.00 I say No big deal just do it. Well after they do there fix they take the truck for a test drive they bring it and back and on the rack it gos .By this time theres three guys looking at it I figuer this cant be good so I go over and the manager proceeds to tell me all my ball joints are completly shot. and that I need to take it back to ford.Im pissed.
everytime I take it to ford they tell me take it to the lift shop and then just the oppisite.If you purchase a truck from ford with lift, tires everything done who should have be responsible to fix it.
Old Nov 13, 2008 | 05:08 PM
DCSpecial's Avatar
DCSpecial
If you bought it lifted from Ford and they told you the warranty, they should have to get it taken care of.....IMO.
If that means they fix it or whoever did the install fix it.
Out of curiousity, where are you located?
Old Nov 13, 2008 | 06:08 PM
richcraft's Avatar
richcraft
The truck has a full warrenty the problem is they keep blaming each other. I called ford and spoke with the service manager they said bring it in and they will look at it. How far you think that will get me. I am in so cal.
Harley250SD
6.4L Power Stroke Diesel
Nov 8, 2013 07:42 PM
galaxie641
Sep 27, 2012 09:47 PM
96f150
Mar 23, 2007 08:25 PM
jth731
15
Feb 24, 2006 09:44 AM
truebluefx
2004 - 2008 F150
Feb 13, 2005 11:38 PM
