Sponsored by: Real Truck
Ignition Cylinder problems
Old Nov 12, 2008 | 07:05 PM
DonovanMaxwell's Avatar
DonovanMaxwell
I just replace the shift lever in one of my company's F-450s today and of course had to pull the ignition cylinder out. Evidently a part must have fallen off that I didn't see because now when I turn the switch and try to start the truck, I don't feel the spring that turns the cylinder back to the run position. I was told by Westway Ford that I was missing a couple parts, but I can figure out how the heck they fit together. One is a green plastic piece and the other is a bare metal piece. I do have the little gear that fits onto the end of the cylinder.
I'm at my wit's end here. Any ideas? I need to get this fixed soon. It's needed on some job sites.
Old Nov 13, 2008 | 08:03 AM
DonovanMaxwell
Well I ended up getting the cylinder and the gear in there good enough that it is now functioning, at least temporarily. I still need to figure out how to get those other parts in properly. Here's the part numbers from Ford:
F2DZ-3E700-A Bearing (bare metal)
F2DZ-3C610-A Retainer (Green plastic)
Old Nov 13, 2008 | 01:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
WELCOME to FTE!
What parts are still not back in?
Old Nov 13, 2008 | 04:24 PM
DonovanMaxwell
The two listed above still need to be installed to keep everything within spec.
So far the truck is working food. The driver of the truck didn't notice any difference in the ignition.
After this week, I'm glad it's over. I just got done replacing the shift lever, gear selector cable, rear brakes (pads, shoes, and rotors) and while I had everything apart I replaced the seals and bearings. All this while still putting out all the other fires the company can throw at me.
I've been the only mechanic for the company for a couple months now. I have 2 dump trucks, 1 cement truck, 7 pickups, 2 F450s, and about 30 other pieces of equipment. To say I am more busy than I can handle would be an understatement. Not even so much as a raise or an attaboy for stepping up to the plate. I have 2 years experience as a mechanic and just starting learning how to weld this past year. Now I have to do it all myself.
Anyone know of a job opening in Dallas, TX? I'm getting screwed where I'm at...
Old Nov 13, 2008 | 06:15 PM
krewat's Avatar
krewat
And the problem is, the more you can keep up your end, the more they think you can handle it and never change anything.
Write a nice letter to the owner.
TexasGuy001
Jul 17, 2012 03:23 AM
Blitzcraig
Mar 5, 2012 10:45 PM
slenser
Dec 10, 2010 08:56 AM
twinpeaks
Jan 31, 2010 08:52 PM
RedSport
1997 - 2003 F150
Oct 12, 2006 07:30 PM
