2005 explorer coolant???
Old Nov 9, 2008 | 09:45 PM
9d4's Avatar
9d4
I need to check on my moms 2005 explorer make sure coolant level is good....if not what kind of coolant do I add?? I think she topped it off with prestone last winter I know your not supposed to mix certain coolants
Old Nov 10, 2008 | 08:06 PM
Ultramagdan's Avatar
Ultramagdan
If colors match you should be fine. Some of the new stuff is labeled to mix with anything. Check the label on the container first. If it was topped off last winter it shouldn't need any.
Old Jan 31, 2009 | 08:24 AM
uno's Avatar
uno
if it is a 2005 you must match the ford collant and do not mix. if you do mix it will eat from internally some of the plastic fittings and cause leaks in places not so fun to work on. it does not have to be ford brand coolant but at minimum match, even more so on the newer explorers and fords. i am in the process of finding a top side motor coolant leak in our 2005 explorer 4.0 as well. ( any help is much welcomed )
willi
Jun 29, 2015 07:02 AM
Coondawg
2004 - 2008 F150
Dec 9, 2012 09:31 AM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
donhclark
May 23, 2003 01:11 PM
