Towing 5th wheel with
Old Nov 19, 2008 | 01:45 PM
  #31
grafekie's Avatar
grafekie
What about brakes, frame size, and axles?
Old Nov 19, 2008 | 04:36 PM
  #32
nemobert's Avatar
nemobert
Brakes are 4 wheel disc, were not back then, frame is boxed good and strong, axles I will give you that but have 100,000 kil warranty (60,000 miles). and I don,t think they will be taking a beating. Have to admit I am enjoying everyones thoughts
Thanks
Old Nov 19, 2008 | 05:04 PM
  #33
thatsme's Avatar
thatsme
Originally Posted by nemobert
Yes it is near the max but I am told it is fine ,by the Ford Dealer and RV dealer. the 09 ford 150 has a payload of 1750lbs if you look at the specs for 3/4 tons from 99-2000 the new 150 do just as much as they did back then
Yes, as much as I hate to admit it, 09 F-150 is comparable to 99-2000 F-250 's. From exp. I would step up F-250 w/ v-10 & a steeper gear 3.73 or 4.10. I tow a 30 ft. 5th-wheel it weighs 10,000 lbs. I did it with my F-250, it was not a good experience. It was ok at best on flat land, but on the hills it was bad. This is why you need to know weights of the truck & trailer loaded & ready to camp.
Good Luck!!!!
Old Nov 19, 2008 | 06:16 PM
  #34
jrf250's Avatar
jrf250
They have trailers (newer) today that are light weight and are for 150 trucks. A 93 year models are heavy. Check the weight on the trailer. I pulled a 27ft 5er with my 150. Had to bag it to hold the weight and then it was scarey to drive. Truck was to light for that big of a trailer. No way would I try to pull double with it, torque is not there on a gas burner. Sold mine and gor a diesel 250 and love it. Can sit back and relax while driving.
Old Nov 20, 2008 | 07:50 AM
  #35
nemobert's Avatar
nemobert
The trailer is 8500lbs and a tonque weight of 1600 should be able to handle it no problems
Old Nov 20, 2008 | 02:24 PM
  #36
grafekie's Avatar
grafekie
Tongue weight of 1600lbs is a HUGE amount!! You'll need a class V hitch. You really should be looking at a SD truck, that's too much for a half ton. But, you may have to learn the hard way, by doing it and realizing you have too much trailer for the truck. Hopefully you won't drag any innocent fellow drivers into your realization
Old Nov 20, 2008 | 04:28 PM
  #37
WestxSRT10's Avatar
WestxSRT10
Originally Posted by ranger56528
a 08 F150 supercrewcab 4x4 with 5.4 and 3.55 rear.Is this possible to do with out damaging the tran or excessive rearend wear....
Iam looking at a 24-25ft 5th wheel so I can also tow a 14foot flat trailer with my atv's,Harley's and my Ranger dependind on what Iam going to do...I will be adding the ride rite airbag sytem to keep sag to a min....Also Iam a flatlander so towing up BIG hills is going to be minimal being how MN and ND aint got much for hills...
Iam trying to stay away from a pull behind toy hauler and dont need to spend alot on a 5th wheel being how Ive found a few for the 7-12 grnd range that fit the bill...
Let me know when your headed out with that load so i can be far away in the next state.
That 5th wheel is all your 150 can handle.
Old Nov 20, 2008 | 07:34 PM
  #38
BPofMD's Avatar
BPofMD
Veteran: Navy
You MAY be able to pull that load, but you are going to find it very difficult to STOP!
Old Nov 20, 2008 | 08:35 PM
  #39
senix's Avatar
senix
he will be using the fred flintstone method for braking
Old Nov 21, 2008 | 12:55 PM
  #40
nemobert's Avatar
nemobert
You guys are just getting to funny. Ha Ha. It sure is good to know how much more knowledge there is on this site than a true Ford mechanic who owns a dealership and an RV dealer who has way more knowledge than Fred Flintstone on here. How the heck did a 3/4 ton truck back in the late 90's-2002 tow fifth wheels? There must have been lots of sore feet back then as they did not have 4 wheel disk brakes back then. I think the brakes of today are far more superior than then.
Old Nov 21, 2008 | 01:10 PM
  #41
senix's Avatar
senix
Manual trans...and home made hitches.
Old Nov 21, 2008 | 01:24 PM
  #42
WestxSRT10's Avatar
WestxSRT10
ever hear of common sense?.... Visualize a F-150 towing a 8000# 25' 5th wheel and a 14' flatbed with 3 ATV's behind the 5th wheel. Thats got to be over 17,000# total weight and 55'-60' foot long.
Old Nov 21, 2008 | 01:46 PM
  #43
grafekie's Avatar
grafekie
Salesmen are just that... many will do ANYTHING to sell anything to you. Some will even sell you your own car!
jg96powerstroker
Jan 11, 2016 02:05 PM
jg96powerstroker
21
Oct 26, 2015 09:25 PM
al0311
Aug 22, 2015 08:58 PM
SteelHorse08
2004 - 2008 F150
15
Mar 8, 2008 03:57 PM
camarokid81
Aug 12, 2007 09:58 AM
