Are the speedometer cables the same for a c4 and a c6 tranny? I found one on rock auto but it was for a c6 and the other cable the had said it was for a manual trans. I know mine is a C4 and is an auto anybody know where i can get a new one for cheap? Thanks Bobby
Unfortunately my outer cable housing is messed up. I was cutting out my floor pan and accidentally cut it in half! I just looked up that part# and it seems like just the one i need. Here's a good question for you if I'm running 18" wheels on my truck how many teeth on the trans gear do i need to have?
Speedo gears are listed by: engine size, trans type, rear axle ratio and tire size.
Even if you give me the three out of four requirements, since 18" wheels were never offered for these trucks, there's no way to look up the gear.
Sorry.
rim size is a worthless mesurment. it is the tire OD that is important you can have a 33 inch TIRE with a 20 inch rim or a 15 inch rim and it wont make a diff on speedo read outs.....
It may be worthless to you, but you don't have the parts catalog, and pray tell, where oh where is the OP going to find out what the correct gear is?
From a crystal ball?
How can I look up in the PARTSCATALOG any speedo gear for a truck that has 18" wheels when only 15's or 16's (optional) were originally available?
Ford goes by the tire size, and there ain't no 18" tire sizes listed either.
but if he has the stock tire size (for a 15inich rim) what does the rim matter...
does the 15 inch and 16 inch rim have a different speedo gear? and tire size? what sizes are the tires stock and what size does the OP have if they are the same then who cares what rim is on there?
and if he has the wrong size tire the parts catalog isnt going to do him much good anyways....
OK kiddo...you asked for it...this is what I have to go by.
I'll use a certain SoCal FTE members truck for an example.
Bill is still struggling with the fact that the world turns outside of the parts book. As correctly stated the height of the tire can be figured out and used to find the correct imput.
John
The parts catalog is ALL I have to go by, John.
I have NO OTHER WAY of looking up the friggen gears!
If the OP wants to figure out what his 18" tires compute to 15" sizes, then I can proceed.
Monkeyman, I had mine replaced by a small shop here in town where the guy makes them. He has rolls of outer housing and inner cable. He just cuts it to length and adds the end parts from your original. I walked in at closing time and he did mine in about 10 minutes for cheap. Otherwise, head over to the junkyard. You'd be hard pressed to find one any cheaper.
Thanks Bill---again you came to the rescue---for me......as always/Bill-1971 F100 302 C4--with stock 15'' original size wheels as in the book......LOL......THANKS
Thanks guys for the info the only reason I didn't state what size tires im running is because if haven't decided yet. Right now im looking at a 302, 373 gears, C4 tranney and more than likely 245/50/18 for tires but will propably go smaller if i can get the tires at the right price.
