1983 F100 Starter Issues
Old Jan 4, 2015 | 03:56 PM
Colejj297's Avatar
Colejj297
I have a 1983 F100 auto with 300 L6 and C6 transmission from a 1980 f150. Starter is the right one for the transmission but whenever I try to start it, it makes an awful grinding sound. Ive replaced the solenoid and cables. Anyone know what might be going on?
Old Jan 4, 2015 | 04:58 PM
Gary Lewis's Avatar
Gary Lewis
Welcome to FTE!!
Not sure what a "ridging sound" is, but I'm thinking it could be one of three things:
  1. Solenoid Chatter: if the noise is coming from the solenoid you have a bad cable or connection. You say you've replaced the cables, but does the negative cable go to the engine or frame? It should, actually, be both and where they connect should be shiny.
  2. Drive Gear: If the drive gear on the starter or the ring gear on the flex plate are bad you'll get a horrible grinding sound. Pull the starter and look.
  3. Battery: If the battery is low or has a bad cell it won't provide enough current to run the starter and the solenoid can chatter. Have the battery tested.
Old Jan 6, 2015 | 05:16 AM
silar's Avatar
silar
Definitely want to have the battery checked out.
Gary.. He said grinding.. not ridging.. lol!
Old Jan 6, 2015 | 07:50 AM
Gary Lewis's Avatar
Gary Lewis
Well, I guess I need my glasses checked. But, if it is grinding then I'd pull it and look at the teeth on it as well as the flex plate.
Old Jan 6, 2015 | 08:04 AM
Dorsai's Avatar
Dorsai
Your glasses are fine; it did say 'ridging' to begin with, I believe someone corrected it.
Old Jan 6, 2015 | 08:12 AM
Gary Lewis's Avatar
Gary Lewis
Thanks! I looked but it doesn't say "last edited" so I assumed it was me. I wonder if one of the mod's is having fun?
Old Jan 11, 2015 | 07:48 PM
Colejj297's Avatar
Colejj297
Does anyone know how many teeth the starter should have for the 300 I6? I think that might be part of the problem.
Old Apr 1, 2015 | 07:52 PM
Colejj297's Avatar
Colejj297
Hey all, I found i had the wrong starter. I was using a 10 tooth instead of a 9. but that didnt totally stop my issues, the top bolt keeps coming loose. Any advice?
Kyle Wood
Jul 10, 2019 10:36 PM
Mikey1996
Jul 18, 2016 07:36 PM
ottawa_dave
Jul 10, 2007 10:04 PM
51PanelMan
29
Oct 20, 2005 09:42 PM
gordo350
Nov 19, 2004 06:22 PM
