Oil Capacity
Old Nov 8, 2008 | 09:33 PM
scatgo's Avatar
scatgo
Oil Capacity
Any one know the capacity of my rear differential? Is 80-90 weight Royal Purple ok?
Old Nov 9, 2008 | 04:12 AM
immastrokinnow's Avatar
immastrokinnow
i think it is just shy of 4 qts. i think....
Old Nov 9, 2008 | 07:20 AM
Cuda_jim's Avatar
Cuda_jim
Yep, 4 quarts should do it. My rear diff has a tag with 75w140 Syn on it. ($15/Qt)
Some guys use 80w90 but I don't know for sure if it's OK. I try to follow the factory
recommendations.
Old Nov 9, 2008 | 08:35 AM
scatgo's Avatar
scatgo
recommendations.
I came across the same information saying to use 75w140 when I was trying to find the capacity. The Ford Diesel Supplemental manual also says to use a friction modifier. Ever hear of this stuff?
Old Nov 9, 2008 | 08:41 AM
ron86toy's Avatar
ron86toy
If you have a LS use a friction modifier...if you are going to Royal Purple you do not need it.....as well with most synthetics you will not need the modifier
Old Nov 9, 2008 | 09:03 AM
Cuda_jim's Avatar
Cuda_jim
Most synthetics have friction modifier like Ron said but they usually do not contain
enough IMO. I add an additional 8 ozs. You can get it atmost auto part stores.
There are some here that do not use the modifier at all, it makes the clutches a nosier
and may wear out a sooner but the LS will grab sooner and hold on longer. If you are
off-roading a lot then leave it out.
Old Nov 9, 2008 | 11:20 AM
scatgo's Avatar
scatgo
Thanks. Tried to rep you all but have to spread the wealth.
Old Nov 9, 2008 | 04:48 PM
immastrokinnow
watch out, motor craft friction modifier smells absolutly horrible. and it is a hard smell to get off you....and out of your nose.....
Old Nov 9, 2008 | 05:06 PM
scatgo's Avatar
scatgo
Thanks for the warning!
Old Nov 9, 2008 | 07:11 PM
tjbeggs's Avatar
tjbeggs
That stuff is nasty! it will stink up the shop for a week! Get it on your boots and your shoes need to come off outside before you get home!
Old Nov 9, 2008 | 09:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe
ummmmm...in your nose.....you arent supposed to sniff it....lol
Old Nov 10, 2008 | 01:38 AM
immastrokinnow
you dont have to sniff it to get that smell in your nose, you just have to be near an open container...
DrFord
Oil & Lubrication
18
Mar 22, 2010 11:47 AM
slowmans
Jun 3, 2007 05:43 PM
FixOnRoadDaily
Oil & Lubrication
16
Nov 10, 2005 05:00 PM
greely-man
Oil & Lubrication
28
Oct 20, 2004 07:31 PM
shendoa
Jul 18, 2004 08:08 AM
