Sponsored by: Kumho
Tire size question
Old Sep 13, 2002 | 07:02 PM
samhihn's Avatar
samhihn
Tire size question
I'm using an E-350 van for work, 89 model. It's got 235/85/16's on it now. They are about 31 plus inches tall. The rims are 16X6 stock steel. Someone is giving me a set of 265/75/16's. They're tall enough and will fit in my wheel wells. Is a standard 6 inch wide rim too narrow? Should I go to a 7 or 8 inch wide rim? Thanks.
Old Sep 13, 2002 | 10:38 PM
blueoval79's Avatar
blueoval79
Tire size question
[updated:LAST EDITED ON 13-Sep-02 AT 11:38 PM (EST)]you should be fine. When i had my mustang i ran 10.5" tire on a 7" wheel.
Old Sep 14, 2002 | 07:35 PM
MustangGT221's Avatar
MustangGT221
Tire size question
How wide are those tires? I don't know my metric conversions but if it's over 10" no way is that safe. Might be ok for a mustang with a more low profile tire but not for a truck. You risk popping the bead when making a high speed turn or safety manuver. You can drive on it ok, but anything more than 10" will be very risky, and I bet a tire shop won't even mount it.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 14, 2002 | 11:15 PM
samhihn's Avatar
samhihn
Tire size question
Thanks Justin. I think your answer is correct...I was just kinda' hoping. The cross section is about 10 1/2 inches. I'm thinking I'd have to go to about an 8 inch rim. Oh well.........
Old Sep 15, 2002 | 02:36 PM
MustangGT221
Tire size question
Rule of thumb, width of rim plus 4" will give you the minimum. Like I have 11.5 inch wide tires on 7.5" wide rims. The manufacturer recommends nothing less than 8" on a 11.5" wide tire, but that .5" is ok, but nothing more. So if the tire is 10.5", you can have a rim anywhere from 7-9" wide.
Old Sep 15, 2002 | 06:11 PM
samhihn's Avatar
samhihn
Tire size question
Thank you, Justin. Is this a great web-site or what
Old Sep 16, 2002 | 03:27 AM
MustangGT221
Tire size question
No problem Mike, thats what we are here for . I've learned most of what I know from this site, I absorb information like a sponge
Old Sep 21, 2002 | 12:29 PM
Scotte's Avatar
Scotte
Tire size question
My 01 F250 Super Duty came from the factory with Firestone Steeltex A/Ts that are LT265/75R16, load range E on factory aluminum 16x7 wheels. I just put a set of Goodyear Wrangler MT/Rs that are LT285/75R16, load range D on factory steel 16X7 wheels for use on the beach. They look great. I am looking forward to trying them out next week.
Good Luck.
Old Sep 21, 2002 | 07:11 PM
MustangGT221
Tire size question
hail destroyer
Mar 3, 2017 05:11 PM
rustyleerusk
Aug 22, 2015 11:58 AM
oldirtytruck
Offroad & 4x4
13
Sep 21, 2010 10:04 PM
richard_d
Dec 24, 2002 10:02 AM
