Sponsored by: Auxito
P0171
Old Nov 8, 2008 | 07:42 AM
greg06012000's Avatar
greg06012000
P0171
Help.....have been getting this error code for the last several weeks......anybody else have to deal with this one......any help would be appreciated. 97 f150 4.6L
Old Nov 8, 2008 | 08:05 AM
tj0911's Avatar
tj0911
try the search mode and enter the code. Seems like I have seen alot on this here before.
Old Nov 8, 2008 | 08:08 AM
greg06012000
did a search.......bank 1 lean condition. apparently there's more air than fuel in the mixture which causes the lean condition. bank 1 is the passenger side according to the search,
Old Nov 8, 2008 | 08:14 AM
tj0911's Avatar
tj0911
sorry not a mechanic here. I typed in po171 and got 8 pages of threads. Hopefully someone will reply soon, cause I saw you have a thread on this already with no replies. Sorry I could not help ya out. This seems to be a common issue.
Old Nov 8, 2008 | 08:16 AM
Denis Gaulin's Avatar
Denis Gaulin
P0171 or P0174 are similar. Clean de MAF sensor very well- I have done it and it worked for me
Old Nov 8, 2008 | 08:55 AM
eallanboggs's Avatar
eallanboggs
What things effect Bank 1 only? What things effect both banks? There's your dividing line. You're lean on bank 1 only, but bank 1 has 4 cylinders. Which cylinder is lean. You don't know and neither does the computer. You have to figure it out. Are you lean because bank 1 isn't getting enough fuel OR is bank 1 getting too much air without also giving additional air to bank 2. Is an injector malfunctioning. Is the pintle stuck closed? Are the injectors being commanded open at the proper time and with the proper pulse width? That's a start.
78ford f250
Nov 16, 2009 12:37 PM
NateDu
Dec 8, 2008 08:56 AM
784x4
Jan 25, 2006 03:30 PM
69isfine
1947 and Older Ford Trucks
Mar 17, 2004 07:27 PM
emboyd
1978 - 1996 Big Bronco
Feb 9, 2002 11:06 AM
