HELP!!!!!!
Old Nov 15, 2009 | 07:31 PM
78ford f250's Avatar
78ford f250
HELP!!!!!!
i have a 1978 f250 and im trying to find out what eng and trans i have in it can any one help???
Old Nov 15, 2009 | 07:33 PM
peganit2's Avatar
peganit2
How many valve cover bolts does it have?
Old Nov 15, 2009 | 08:30 PM
classicfordman's Avatar
classicfordman
do you have a square sticker on the side of your valve cover?....if you do and can read it then it should have the engine size printed on it....if not you will have to get the nubers off the block near the bell housing and then after you get those numbers, you will need to repost them on here and ask "numberdummy" what it means.....he can tell you any thing you need to know about any part number you can emagine....he knows his stuff...
Old Nov 16, 2009 | 12:32 PM
78ford f250
help is better
it says its a 351m what is the m??
Old Nov 16, 2009 | 12:37 PM
Holiver31's Avatar
Holiver31
The M stands for modified. The 351M is identical to the 400 except it was "modified" with a shorter stroke. The 400 has a 4" and the 351 has a 3.5". The numbers fudge a little if you do the math, the 400 actually has 402 CI.
dunkley20
Apr 2, 2013 05:07 PM
shamp
May 1, 2010 04:03 PM
pentel
94
May 21, 2007 01:45 PM
yzwilly
General Diesel Discussion
Feb 27, 2007 03:26 PM
ford99
Jul 1, 2006 01:23 PM
