General Automotive Discussion
project
Old Nov 8, 2008 | 07:40 AM
thickone's Avatar
thickone
project
hello guys
looking for my first ford project truck ( trail & mud slinger) need some help
what is the last year f-150's had solid axles or is their other years that are more popular to do up? 60s 70s early 80s... 250s / 350s
thanks.
thickone
Old Nov 8, 2008 | 04:16 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
wrong forum, but
Ford hasn't had a solid axle in the F-150 since 1981...or was it 1983? Pretty sure 1981 though. In 1982 they introduced the TTB independant front suspension. That was in use until 1996 (1997 for Superduty).
TTB is a semi-solid axle setup...the axle is in 2 peices and looks like an "X". Actually is a pretty good setup.
You can do a solid axle swap into the 82-96 F-150 fairly easily though. Just need the axle from a 70's Ranger/Bronco/F-150 and the radius arms, control arm.
but if you are wanting to build a Ford trail truck, a 70's F-150/Ranger is the way to go. Solid axle, heavy duty drivetrain and a big block bolts in relatively easily
Old Nov 9, 2008 | 06:28 AM
dixiemudder04's Avatar
dixiemudder04
The best project i ever tackled for that is a 78 f150. Had the dana 44/9" combo. c6 tranny, that thing was stout. Just got rid of it last wednesday. Theres some pics in my gallery of it.
Old Nov 9, 2008 | 02:09 PM
JKBrad's Avatar
JKBrad
1979 was the last year for a solid axle in the F150 4x4s.
It's a relatively easy swap to put a '73-'78 solid axle in the '80-'96 F150s.
Old Nov 9, 2008 | 02:55 PM
Ford_Six's Avatar
Ford_Six
Yup, I did that swap on an 84 F250 using all Ford parts and perches that I made. I had to cut and rotate a drag link to hook the steering up, but that was easy.
I would start with an F250 as suggested, but the first mod would be to change the steering to a crossover system. The steering arm system with hydraulic assist sucked on a good day, once you start lifting and modifying, it becomes a royal pain to deal with.
Also beware of some 76-77 1/2ton 4x4s, they had a y-steering linkage, where the drag link ran to the right knuckle, and the tie rod to the left knuckle came off the middle. Horrible bump steer, and very hard to keep aligned. A surprising number of companies used this system, too.
Old Nov 9, 2008 | 08:50 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
what year is your truck?
That would help greatly.....
Ducky F150
May 4, 2013 03:05 PM
quehegan
Projects
Sep 2, 2012 11:48 PM
Davidwent
Jun 7, 2011 06:01 AM
B777 Driver
Dec 31, 2010 06:55 PM
uc4me
Feb 10, 2006 05:05 PM
