2000 Ranger wiring issues
Old Nov 7, 2008 | 05:32 PM
sixstringsamurai's Avatar
sixstringsamurai
A couple years ago I had some problems with my Ranger. Basically, the rear window was leaking and whenever it rained, the padding underneath the floor mat would get soaked. Since the floor itself was dry, I didn't even realize, but over time some serious corrosion developed in the connector underneath the driver's seat. Its connector 309 and to fix the problem, I cut the male and female sides off and soldered the wires directly together. Everythings been fine, but now I'm getting EVAP codes off the computer and it seems to be because of this wiring. So does anyone have a fairly detailed wiring diagram so I can trace which wires go where and redo the connections?
Old Nov 7, 2008 | 07:10 PM
Rockledge's Avatar
Rockledge
Check out: Harness Connector C309
Old Nov 9, 2008 | 10:03 AM
sixstringsamurai
I actually have that diagram, but it doesn't tell me which wire goes where. Unless I'm missing something, which is very possible.
Rockledge
Sep 12, 2016 10:00 PM
madizon1420
Apr 15, 2016 06:36 PM
ptm
May 3, 2013 09:17 AM
JW1971
1978 - 1996 Big Bronco
Apr 6, 2011 05:19 AM
jrg24
Oct 3, 2009 03:39 PM
