tranny issue
Old Nov 8, 2008 | 05:41 PM
muddpuppy01's Avatar
muddpuppy01
tranny issue
01 ranger 3.0 4x4 5r55e
my tranny is acting up hold the gas down from a stop it bounces off the rev limiter drive normal and it wont go into o/d tried the 1 gear manual test and it is as you are in neutral and the fliud does not smell burnt
I went ahead and changed out the valve body gasket and separator plate put a new filter in and it is still doing it. I did not see any blow outs in the gaskets on the plate.
when I pulled the pan there was a fair amount of metal flakes and the magnet had a bunch of what seem to be metal dust on it.
I had it rebuilt 2.5 years ago
you think its time for another rebuild or you think I can salvage it still. There is no slipping while driving.
Old Nov 9, 2008 | 06:20 AM
wendell borror's Avatar
wendell borror
I hate to say it, but it sounds like time for another rebuild.
Old Nov 9, 2008 | 12:51 PM
Bear River's Avatar
Bear River
Former ******
This time around, make sure they rebuilt it right, with the proper solenoid bushings to compensate for the wear. The solenoids wear into the case, and so unless you do a bushing kit or replace the case, the problem will come back.
