HELP HELP HELP - need advice
Old Nov 7, 2008 | 01:58 PM
Hunter3285's Avatar
Hunter3285
wow, what do you all do for a living. thank you so much for the help
Old Nov 7, 2008 | 02:03 PM
just another truck's Avatar
just another truck
Drink and throw out dumb ideas on the computer.....scary huh?
The longer you hang out here, the more you will learn that these people on this site, are great!!! Stick around.. we come from just about ever job description you can think of. There is even a thread about it.
https://www.ford-trucks.com/forums/6...-a-living.html
Old Nov 7, 2008 | 03:37 PM
Action4478's Avatar
Action4478
Keep us posted ,
,others will be along with many more ideas...
Pull up a comfy chair ...& hang around awhile
BTW ,,welcome to FTE...
Old Nov 7, 2008 | 07:14 PM
tommyl's Avatar
tommyl
Does the truck start and run any better if you plug it in?
Old Nov 7, 2008 | 07:28 PM
F350-6's Avatar
F350-6
How long have you had the truck? How many miles has the oil been in the engine (and is it still full)? Did the problems start right after you switched to synthetic? We have one member here who's truck didn't like the synthetic (kwikkordead). At what interval has the oil been changed in the truck? To check for a stuck open thermostat, you'll have to feel the radiator hose to see if it seems to be warming up with the engine instead of staying closed and keeping the coolant in the block.
If you talk to any more shops, ask them how they came up with their diagnosis. Is it from their experience (aka guessing) or did they hook it up to a computer for diagnostics? If they used a computer, what readings did they monitor to come up with their proposed repair?
As Rick mentioned, monitoring ICP psi, IPR %, EOT, to get a gauge on things. A buzz test on a cold engine, followed by repeated buzz tests, will tell you if there might be some injector issues with the cold oil. A good shop can also do a contribution test on the cold engine by wiring in a resistor on the EOT sensor.
If you want to unplug the ICP sensor as Rick suggested, it's the round looking thing on the front inboard side of the drivers side head. Unplugging it will cause the PCM to assume default readings to aid in start up. It looks like this.
Now that we've gotten that out of the way, I'd like to back up a few steps. Can you give a better description of the starting and running issues? How long do you have to crank it when it's cold out before the truck starts? Is there any smoke out the tailpipe while cranking? Any smoke when it starts up for the first minute or so? If so what color smoke?
As for the running issues, it's common for a diesel to be louder when cold, and the EBPV (exhaust back pressure valve) will close to increase back pressure aiding ina quicker warm up. This will make the engine sound different, and you get that lovely jet engine sound when you hit the go pedal.
Also, just to be on the safe side, when was the last time the air filter and fuel filter were changed?
Old Nov 8, 2008 | 12:14 PM
kent's f-350's Avatar
kent's f-350
welcome, sounds just like what my truck was doing, and i also changed every thing gpr, gp's injector o-rings, sensors, and still ended up replacing the injectors, and now it pops right off, even when cold. sorry full of bad news. but i talked to a guy over at international (not ford) and he said that the silenoids in the injectors don't want to work when the oil is cold. mine would'nt hardly start when it got below 40* and missed on a few cyl. till warmed up. but i would have someone do a buzz test on them when the oil is cold and then when it's up to temp also. and see what that does. i did not have a way or any one to do this test so i took a shot in the dark and it was it. also when it's up to temp do you think there is any power loss? mine had some, but if you just bought it you prob. would'nt know. (i did'nt)
Old Nov 8, 2008 | 12:18 PM
kent's f-350
i don't think it's a themostat b/c the motor is already cold. my .02
TheGoo
Jan 14, 2011 12:05 PM
03F2507.3
Jul 7, 2008 11:45 PM
10bands
18
Jun 4, 2008 09:14 PM
JCastellaw
Oil & Lubrication
18
Jan 30, 2004 03:16 PM
wldwilliam
Apr 8, 2001 08:01 AM
