torque converter?
Old Nov 6, 2008 | 09:50 PM
someday's Avatar
someday
torque converter?
i cant think anymore after being up over 48 hrs and i want to confirm my engine is seized and its not the starter or trans...the torque converter rotates whenever the motor is running, regardless of gear right? so its not possible to rotate the converter without rotating the engine? if the trans locks up will that lock up the engine?
Old Nov 6, 2008 | 10:24 PM
05chop's Avatar
05chop
Sorry about your mishap can you tell us what happened?
Old Nov 6, 2008 | 10:52 PM
someday's Avatar
someday
i bought a 95 v8 4.6l tbird monday and it ran fine...it had a tick that went away and an engine code P0102 for the MAF...almost made it home and it died...got it to start at wot but it would knock real bad and it back fired...when it backfired the entire plastic air cleaner blew up into pieces...tried to start it today with a new air cleaner and another maf...same problem and only starts at wot and needs gas to stay alive at 1-2 rpms knocking bad...felt like the starter jammed so i cranked the engine by hand and it is getting hung up...it will almost make a full rev but it jams up and i hear it hit metal on the pside...i dont understand how it could have run so well...after more attempts to start it will not crank at all and ive broken the crankshaft bolt
Old Nov 7, 2008 | 02:55 AM
stuart1's Avatar
stuart1
It's seized.
Old Nov 7, 2008 | 07:36 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Right.
Right. You can't rotate the torque converter without rotating the engine.
No, it will not.
You have an engine problem, not a trans problem.
Old Nov 7, 2008 | 08:38 AM
Lazy K's Avatar
Lazy K
You could have water in one of the cylinders. ( blown head gasket?)
Old Nov 7, 2008 | 09:40 AM
someday's Avatar
someday
i had all the plugs out...it might have flooded the engine trying to start at wot
Old Nov 7, 2008 | 10:17 AM
Mark Kovalsky
You can't flood the engine cranking at WOT. At WOT in crank the PCM turns off all the injectors to clear a flooded engine.
Old Nov 7, 2008 | 11:12 AM
someday's Avatar
someday
what else does the pcm do at wot because that was the only way i could get it to start?
the oil level on the dipstick looks significantly higher and reeks of gas...not milky though i could have sworn the bottle was full not its empty
Old Nov 7, 2008 | 01:34 PM
Mark Kovalsky
That is the only special thing that the PCM does at WOT during crank that I know of. Everything is pointing to an overfuel condition. It's getting much more gas than it needs.
Old Nov 7, 2008 | 02:24 PM
Lazy K's Avatar
Lazy K
Whst the original problem was I don`t know. It sounds now that either you have a valve stuck open (unlikely), or you have a slipped/broken timing belt/chain, or you have a bent/broken con rod.
Old Nov 7, 2008 | 02:41 PM
someday's Avatar
someday
i think it probably dropped a valve but its toast now and i dont want to waste anymore time or money on this car ive owned for a week and drove less than an hour
Old Nov 7, 2008 | 07:28 PM
bashby's Avatar
bashby
Lots of gas in oil, locked engine... Sounds like maybe an injector hanging open and filling a cyl or 2 with gas hydr-locking it...did youo say it was still locked with plugs out?
Old Nov 8, 2008 | 12:05 AM
someday's Avatar
someday
more like fused with all plugs out
