coolant question
Old Nov 8, 2008 | 01:10 PM
nlemerise's Avatar
nlemerise
Delo (Chevron) ELC is good for 750,000 miles (1,000,000 if you add the supplement package at 500,000 miles) and no more SCA testing ! The coolant was $18 per gallon (undiluted, and I had to buy a case of six gallons). I changed mine and installed a coolant filter at the same time...$72 for coolant, $15 for distilled water, and $100 or so for the filter system. Now, I need to change both the Volvos and I will never have to change coolant again (at least on these three vehicles). Can anyone see a reason why the Delo ELC wouldn't work in the Volvos?
Old Nov 8, 2008 | 01:13 PM
nlemerise's Avatar
nlemerise
Originally Posted by makohon
also one more thing how long does it take cavitation to happen? because i used one of the fleetgaurd test strips and if im reading correctly it reads 0!! the nitrate is at A on the chart and the molybdate is row 2... hopefully this hasnt been like this for a long while.. ive owned the truck for only a year ''02 150k'' you read the strip with the part you hold onto at the bottom of chart correct? well im going to my IH dealer right now to get coolant and as far as the thermostats go on these can i just but a pepboys one of should i go to the dealer?
I don't know if anyone knows how long...if the SCA's were at zero, I would suspect that some pitting has already occurred. Get the thermostat at the IH dealer...it will be cheaper than the dealer and first rate quality. Make sure the thermostat is the same as the one you take out.
Old Nov 8, 2008 | 02:12 PM
makohon's Avatar
makohon
going to safeway and getting gallon jugs of regular drinking water is fine right?
Old Nov 8, 2008 | 02:16 PM
megawatt00's Avatar
megawatt00
You want to use distilled water, not just spring water.
Old Nov 8, 2008 | 02:25 PM
nlemerise's Avatar
nlemerise
deionized water will also work...Oh and you'll need about 20 gallons. Did you read the procedure on switching to ELC coolant? Gooch has a good one...I'll see if I can find it.
Old Nov 8, 2008 | 02:29 PM
megawatt00's Avatar
megawatt00
I'venever seen deionized water in stores. Where would you get it?
Old Nov 8, 2008 | 02:37 PM
nlemerise's Avatar
nlemerise
Our water is so bad out here (though I have an almost unlimited supply 30 feet down) they sell every kind known to man in almost every store...myself, I have a iron/manganese/softening filtration system in my house...but I still buy distilled or deionized when I do coolant and for my batteries (my house batteries use a large amount of water - about a gallon a month).
Old Nov 8, 2008 | 02:56 PM
makohon's Avatar
makohon
is this the link your talking about? Coolant changing instructions... - Diesel Forum - The Diesel Stop.com i just drained all the coolant out as we speak..... all i have to do is pull the thermostat and start flushing it out..... oh by the way i loved pulling the passenger side plug and the coolant spilling allover me until it found its path comming off the starter!!
Old Nov 8, 2008 | 03:17 PM
megawatt00's Avatar
megawatt00
I'll have to look a little closer next time I go to the store. I'm suprised that your well is only 30'deep. Mine is close to 325!
Old Nov 8, 2008 | 06:55 PM
nlemerise's Avatar
nlemerise
The well is 140 feet deep, but static water level is at 30 feet with unlimited (50+ GPM) water...just down a little hill from my house (on my property) is a year round running stream which flows through the property (very rare out here in the desert...we get less than 6" precipitation per year). The city of Sparks wants to annex my property for the water ...they want to put in a commercial well and pipe the water to Sparks...another fountain, another golf course .
Old Nov 8, 2008 | 06:58 PM
nlemerise's Avatar
nlemerise
That's the one! Yeah, that is fun having the coolant running all over you , isn't it? Well, isn't it ?
Old Nov 8, 2008 | 08:07 PM
megawatt00's Avatar
megawatt00
Where it is on your property they should have to compensate you for it wouldn't they? If not we'll
and them!!
Old Nov 8, 2008 | 08:20 PM
  #28
makohon's Avatar
makohon
ok well just finished!!! damn that took way to long...... 6 hrs... well 1 to 1.5 were running to the store bla bla bla...... but i feel much better now than i did before... its like when i do an oil change.. i feel much better driveing after doin a flush.... hopefully the sca level wasnt low for a long period of time!!!! well ill never have to do that again HOPEFULLY!!!! thanks again guys!!! BTW the IH coolant is 18.10 a gallon of concentrate if ne one is curious!!
Old Nov 8, 2008 | 11:37 PM
  #29
makohon's Avatar
makohon
Im confused.............. so i did the flush like it says how to in that link i posted......flushed it with garden hose.... drain.... distilled water.... drain.... distilled water... drain.. then coolant..... so for the last flush with the distilled water i filled up to the top, ran motor.... then unscrewed the drain on the radiator and pulled both the block plugs.. i did not pull the lower radiater hose ''i dont think'' ... screwd the block screws in and put in the thermastat closed the drain valve on the radiator then filled with 4 gallons of coolant and only 2 gallons of water???? that only is 6 gallons???? not 8... the first flush with the distilled water i fit 8 gallons in... can there really be 2 gallons worth of air in the system? if there is that much air in the system should i be worried about driveing it?
Old Nov 9, 2008 | 09:39 AM
  #30
Izzy351's Avatar
Izzy351
You never get all the coolant out of the system, even when pulling the block plugs. 1.5 or 2 gallons is about right. That's why you want to use concentrate and not the pre-mixed stuff.
