coolant question
Old Nov 9, 2008 | 09:49 AM
  #31
nlemerise's Avatar
nlemerise
Originally Posted by makohon
Im confused.............. so i did the flush like it says how to in that link i posted......flushed it with garden hose.... drain.... distilled water.... drain.... distilled water... drain.. then coolant..... so for the last flush with the distilled water i filled up to the top, ran motor.... then unscrewed the drain on the radiator and pulled both the block plugs.. i did not pull the lower radiater hose ''i dont think'' ... screwd the block screws in and put in the thermastat closed the drain valve on the radiator then filled with 4 gallons of coolant and only 2 gallons of water???? that only is 6 gallons???? not 8... the first flush with the distilled water i fit 8 gallons in... can there really be 2 gallons worth of air in the system? if there is that much air in the system should i be worried about driveing it?
You left some of the distilled water from the last flush in there by not pulling the lower hose...you will be fine. Just watch your degas bottle level for a few days and top off with distilled water if need be. The Delo ELC says that you can mix it with a maximum of 25% standard coolant before it degrades from maximum protection. You have so little of the old coolant in there from two flushes, everything will be cool. If you get heat out of the heater, then you have very little to no air trapped in the system.
Old Nov 9, 2008 | 09:57 AM
  #32
nlemerise's Avatar
nlemerise
Originally Posted by megawatt00
Where it is on your property they should have to compensate you for it wouldn't they? If not we'll
and them!!
Oh yeah, they'll have to compensate me at highest market value (thanks to our ballot measure that passed last week) for my 60 acres and house. They'll plow my house and barns over, chainlink/razor wire fence the 60 acres, and drill the commercial well right after they chase my butt off it. The creek, of course, will then be a dry creek and the antelope, mule deer, chukars and quail will be SOL. I didn't even know their intentions until I happened to see the 20 year master plan for Sparks. There was my end of the valley (I live in the end of a high valley surrounded by mountains on three sides - Spanish Springs, which is slowly being gobbled up through annexation, is just over the mountains to my south) marked "for annexation". I knew immediately that it was my water they wanted...contacted the people who are involved with the metro Reno/Sparks water and they said nonchalantly "Yeah, we're going to take your place...don't know exactly when...but it will be condemed and taken through eminent domain." That's when I bought my place in southern New Mexico...I'd love to keep this place for my kids, but I know tilting at windmills is something I don't want to do at my age.
