Home made Leveling kit?
Old Nov 13, 2008 | 09:45 PM
  #31
fxstbchopper's Avatar
fxstbchopper
Originally Posted by DemonRace6
Here's an Ebay auction for leaf springs
If 315's fit with no lift I think the only problem with 325's after a 2.5" lift would be lock to lock, spacers would fix that but I'v never looked into them, not sure if they are a good idea or not...
Yeah I would think with the 2.5 lift they would work fine you would have to use a lift kit not a leveling kit or get F350 blocks for the back and a 2.5 leveling kit as the F250's don't sit as high in the back. I don't like spacers seen to many wheels come off with them back when I was doing low riders.
Not from me as I would not use them back then either.
Old Nov 17, 2008 | 10:50 AM
  #32
DemonRace6's Avatar
DemonRace6
Hi!
Originally Posted by HH60FE
I called Sanderson welding and talked to Mr Sanderson (forget his first name). He recomended the mini spring pack, its what he runs on his rig. I told him NOT to weld them and thats what I got; tow unwelded spring packs, longer U-bolts and two sets of retaining pins. Installation wasn't easy, but I've got probibly 3k on them without any issues. The retaining (center) pin maintains the pack and the ubolts keeps everything stright. No trackbar adjustment needed. Love the new stance.
So he built a custom mini spring pack for you? because Iv only ever seen them welded and that doesn't look like a good idea to me. How much did they cost from him?
Old Nov 17, 2008 | 11:16 AM
  #33
DemonRace6's Avatar
DemonRace6
Hi!
the stock shackles are 5" center to center of the bolts but they are not straight up and down as you can see from Mike's, Big Poppa Pump's, picture. Should the new shackles be 6.5" to raise the truck 2" to 2.5"? I think so...
Old Nov 17, 2008 | 02:14 PM
  #34
HH60FE's Avatar
HH60FE
Joe, I think it was $115 to the door, list for $149. Wasn't really a custom build, he just didn't weld them. Everything was as asvertised.
One hint: I cut about 3/4 inch off one side of each u-bolt (after running two nuts on the thread to assist in recutting any burrs). This helps getting the u-bolts back through the lower base plate. Can't ever seem to get them to spring together enough for both legs of the u-bolt to go through at the same time. Just a thought.
Old Nov 18, 2008 | 12:52 PM
  #35
DemonRace6's Avatar
DemonRace6
Hi!
OK thanks, that's def something I will look into. Right now I have the material to build the shackles and haven't paid anything yet so I will continue with this, for now.
Old Nov 18, 2008 | 01:13 PM
  #36
a-rod's Avatar
a-rod
My 315s rub pretty bad when turned all the way, I think my springs are starting to sag a bit though.
Old Nov 19, 2008 | 09:17 AM
  #37
DemonRace6's Avatar
DemonRace6
Hi!
315/75? Do you think a offset would fix it?
Old Nov 19, 2008 | 09:56 AM
  #38
HKusp's Avatar
HKusp
Those springs have got to be sagging. I have 305's and I am pretty sure I could go to 35's with no issues.
Old Nov 19, 2008 | 11:00 AM
  #39
DieselBeast01's Avatar
DieselBeast01
I've got the 2.5" shackle from Sanderson Welding, and an add-a-leaf kit on mine. I started out with only the add-a-leaf, and the 35s rubbed really bad. I added the shackle and here is what it looks like now. No rubbing at all, even with Nitto Mud Grapplers
Old Nov 19, 2008 | 11:25 AM
  #40
HH60FE's Avatar
HH60FE
Clint, love the stance of your PSD with those 35's. Thats a good lookin' thumb too!!
Old Nov 19, 2008 | 01:07 PM
  #41
DieselBeast01
Yeah, the sun was putting glare on the camera lol. Thanks for the approval
Old Nov 19, 2008 | 01:39 PM
  #42
a-rod's Avatar
a-rod
Well heres how mine sits with the add-a-leaf leveling kit, The leaf extends almost the whole length of the main leaf. 315-75-16s. They rub pretty bad. Im thinking about making some longer shackles as well to cure this.
Old Nov 19, 2008 | 03:50 PM
  #43
DemonRace6's Avatar
DemonRace6
Hi!
So I guess I shouldn't go with 315's huh? heres what i have of the shackles so far:
idk why this pic is not working, here is the link: http://www.flickr.com/photos/joesgroi/3044554032/
Old Nov 20, 2008 | 01:05 PM
  #44
a-rod's Avatar
a-rod
Those shackles wont give you lift for 315s, at least I dont think. I would get a nice looking set of 285 - 305s if I was you.
Old Nov 21, 2008 | 10:08 AM
  #45
DemonRace6's Avatar
DemonRace6
Hi!
I could make them longer, I have 295's on my truck now with no lift, they are 2.5in longer than the stock
