GPR not clicking
Old Nov 4, 2008 | 03:57 PM
Ponyboychris's Avatar
Ponyboychris
OK sorry just checking. The California models (that were delivered and originally sold in CA) had GP controllers like the photo posted by Rick. the first relay is the Air Intake Heater relay and is not part of the glow plug system. Just making sure we are all talking the same.
Old Nov 4, 2008 | 04:12 PM
Izzy351's Avatar
Izzy351
Wait -- he says he has the CA model... That means he has the GPC, not the GPR, but then he says he has two relays.
I guess I'm confusing myself now... You DO have two relays like the pics on guzzle's page and NOT the GPC like Rick posted above, right?
Old Nov 4, 2008 | 04:33 PM
Ponyboychris
I assume he has the two relays like guzzle's pic. So it's not a CA model by definition but the truck is physically in CA.
Old Nov 4, 2008 | 07:17 PM
joes50pu's Avatar
joes50pu
Yes.....two relays . I have the wiring schematic now and will start tracing the wires back to see why the relay isn't activating. I will get back with my findings.
Old Nov 4, 2008 | 09:27 PM
Izzy351's Avatar
Izzy351
Good deal -- let us know!!
Old Dec 27, 2008 | 10:28 AM
Bama Hoser's Avatar
Bama Hoser
Hello. I also do not have a ground being provided by the PCM and do not have access to a wiring diagram. Please let me know what you find out. I know I can install a momentary push button switch to manually give a ground to the GPR and make it actuate, but I am just curious as to why the PCM is not providing the ground.
Does the PCM get temp input from a sensor that may be bad?
Thanks for any wiring info.
Old Dec 27, 2008 | 02:03 PM
strickracing's Avatar
strickracing
has anyone substituted the iah relay for a gpr relay and had any problems
Old Dec 27, 2008 | 04:09 PM
Automator's Avatar
Automator
I was wondering the same thing when my GPR dumped and if they could be temporarily swapped. Mine turned out to be a bad coil, relay didn't even look bad inside when I took it apart. Bought a LED to install inside to monitor it in the future so I can try to avoid any surprises.
Looks like no response from joes50pu as to what he found, and no posts anywhere else. I would lean to the broken wire but that was a good point about a temperature sensor, though I would think it would turn on the GPR year round thinking it was cold. Some temperature controllers do show high if disconnected as a safety so I guess it could be the case. I am curious to know as well.
Old Dec 27, 2008 | 05:06 PM
joes50pu's Avatar
joes50pu
Hi everyone, sorry I hadn't gotten back with a remedy for the GPR not energizing. I had the customer take the truck to the dealer because I reached the limit of my scanner's Capabilities. All the scanner would say was a GPR Malfunction. The Dealer ended up first replacing the engine engine compartment harness but the problem remained. Last I heard they were going to replace the PCM.
Old Dec 28, 2008 | 10:56 AM
Automator's Avatar
Automator
joes50pu, thanks for the update. BTW, welcome to FTE. If you find out what the final fix is, please let us know so it can help others.
therigwelder
Dec 2, 2013 11:30 AM
megawatt00
52
Sep 25, 2012 06:01 PM
Backdraft-14
Mar 17, 2012 05:16 PM
wyattwie
May 7, 2010 09:12 PM
OfficerDangle
17
Jan 6, 2007 08:36 PM
