what else do i need??? help please
Old Nov 3, 2008 | 07:42 PM
2 stroke man's Avatar
2 stroke man
i dont have a plasma cutter, but can gain access to one, otherwise it'll be the old reciprocal saw. on the pipes, i will have to rig up my buddies welder to weld aluminum right?
Old Nov 3, 2008 | 07:59 PM
FARM69's Avatar
FARM69
The pipes should be SS. There might be some aluminum pipes out there, but I think the majority of them are SS.
A sawzawll will work too.. just don't get wild and hit the radiator. You can determine where you want to place the cooler... i.e. up/down. Not sure what the location of a tranny cooler is.. but you might want to put your IC towards the top if that is a clearance issue.
The condenser will have to be moved back a little and the hood latch pushed out some too.
Old Nov 3, 2008 | 08:02 PM
93f1505.0L's Avatar
93f1505.0L
Ya if you get aluminum pipes. Most are steal but some are aluminum. The hardest part on the thing I though was the pipes. Heres a pic of mine I used both 6.0l pipes and the driver 7.3l.
http://i307.photobucket.com/albums/n...aystuff014.jpg
http://i307.photobucket.com/albums/n...aystuff015.jpg
http://i307.photobucket.com/albums/n...aystuff013.jpg
http://i307.photobucket.com/albums/n...aystuff029.jpg
http://i307.photobucket.com/albums/n...aystuff022.jpg
Edit: x2 on everything Farm said too. I used a sawzawll to cut min out. you also have to get rid of the brace that goes up and down just in front of the condessor.
Old Nov 4, 2008 | 06:43 AM
Neal 97 250's Avatar
Neal 97 250
Use a sawzall and I also used a grinder with cutting blades to make fast work of it.
B-Rad88
Jun 25, 2017 11:23 AM
Lhornung
115
Mar 19, 2017 08:51 PM
Splatts
73
May 21, 2012 11:46 AM
Ken_C
Oct 16, 2010 05:10 PM
Fullcrew7.3
Feb 3, 2010 12:16 PM
