what else do i need??? help please
Old Nov 3, 2008 | 05:12 PM
2 stroke man's Avatar
2 stroke man
well, imma intercool the ole gal. i found both pipes, spyder boots, clamps and mounts of $50. i know i need the intercooled and rearly 99 spyder. anything else?
i found an intercooler gaurenteed good for $175 but i think thats too high. what ya'll think? i just need to know what else i need
Old Nov 3, 2008 | 05:13 PM
Cuda_jim's Avatar
Cuda_jim
Look here:
https://www.ford-trucks.com/forums/7...oler-core.html
Old Nov 3, 2008 | 05:26 PM
wmiller's Avatar
wmiller
theres a 6.0 on ebay for like 105. I got mine from GOBANKS on ebay. I was a unit removed to update to a bigger one
Old Nov 3, 2008 | 05:28 PM
2 stroke man
ya, i know... will 7.3 pipes work with the 6.0 cooler ar will i need the 7.3 pipes then?
Old Nov 3, 2008 | 05:35 PM
wmiller's Avatar
wmiller
haven't done it yet but either way you have to cut and make custom. I got 1 set of each
Old Nov 3, 2008 | 05:57 PM
2 stroke man
what do i have to make custom?
Old Nov 3, 2008 | 06:09 PM
Epd444's Avatar
Epd444
The pipes will have to be modded a little bit to fit IIRC. The kit TJ found is a good deal like he said if you got the coin to dish out. I've seen the same kit TJ's talkin about go for almost $700
Old Nov 3, 2008 | 06:11 PM
RubberDuck's Avatar
RubberDuck
Lookin in my intercooler gallery, you can see what you have to do to the pipes.
Old Nov 3, 2008 | 06:12 PM
2 stroke man
but i wont have make any piping will i?
Old Nov 3, 2008 | 06:15 PM
2 stroke man
ok ,thanks rubber duck.
Old Nov 3, 2008 | 06:31 PM
2 stroke man
ok, super stupid question but.....what would keep a man from using that flexible exhaust pipe?
Old Nov 3, 2008 | 06:58 PM
BlueMule's Avatar
BlueMule
It'll leak, the coils are just crimped and don't seal well enough to hold pressure.
Old Nov 3, 2008 | 07:21 PM
FARM69's Avatar
FARM69
x2. Those flex hose deals are junk. They only last for about a season before they rip or rust out.
Old Nov 3, 2008 | 07:25 PM
2 stroke man
so the bulk of the work is cutting the 2 holes and fabricating ur pipes just right?
Old Nov 3, 2008 | 07:37 PM
FARM69's Avatar
FARM69
It's a pretty easy process if you have a plasma torch. It took maybe ten minutes to get the hole cut. A little fabrication on the IC mounts but nothing difficult. It takes more time to remove the grille and stuff.
Intercooler pipes are a little tricky. I had to re-tack them a couple time to get them in the right spot before I welded them up.
Use good boots!!! That is probably the biggest problem with intercoolers.
