My info shows #10 as a 20 amp fuse that powers the starter relay and instrument cluster fuses 15 and 18
Interesting, owners manual indicates above what tj said. Checked my #10 fuse in engine compartment and it too is 30 Amp. Schematic indicates fuse #10 for gas only and fuse #9 for diesel controlling starter relay and instrument cluster. So I'm not exactly sure what fuse #10 does, unless my diagrams are wrong.
Yep owner manual and diagrams here both say the same thing as yours. They don't agree.......I hate that!
What manual are you guys using? My Helms EVTM shows #10 for the starter relay and #15 and #18
And #9 for the PCM, PCM relay, electronic transmission control, IPR and IDM
My owners manual is in the truck and that's not here , so I cant check it.
