Block Heater
Old Nov 1, 2008 | 07:06 AM
ponyboy123's Avatar
ponyboy123
Block Heater
I have read on a few posts that people think all of the 6.0 come stock with a block heater, just no cord. Where is the block heater located(which side, front or back) My f 350 was brought up from the US and I was thinking it may not have one cause I can't find a cord. Up here where I am a block heater is a must so if there isn't one in it I gotta get one put in soon. Puddles are freezin' over already.
Old Nov 1, 2008 | 07:21 AM
bismic's Avatar
bismic
All 6.0's were equipped with the heater. Info below:
<TABLE style="WIDTH: 663pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=884 border=0 x:str><COLGROUP><COL style="WIDTH: 663pt; mso-width-source: userset; mso-width-alt: 32329" width=884><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 663pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=884 height=17 x:str="Block Heater Cord install - in climates that get below 10 degrees F; Part # 1C3Z6B018AA - $54.90 ">Block Heater Cord install - in climates that get below 10 degrees F; Part # 1C3Z6B018AA - $54.90 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 663pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=884 height=17>Ford part #: 4C4O6B018AA International Part #: 1686485C91</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 663pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=884 height=34>http://catalog.powerstrokeshop.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214083&pa rtnumber1=1C3Z6B018AA&Makeid1=10&catalogid=0&searc hType=Part%20Number%20Search%20Results&searchAll=1</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 663pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=884 height=17>https://www.ford-trucks.com/forums/700325-installing-a-block-heater.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 663pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=884 height=17>https://www.ford-trucks.com/forums/661836-engine-block-heater-cord.html</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 540pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=720 border=0 x:str><COLGROUP><COL style="WIDTH: 540pt; mso-width-source: userset; mso-width-alt: 26331" width=720><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 540pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=720 height=17>Block Heater Cord</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 540pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=720 height=17>http://www.forddoctorsdts.com/articles/article-05-20.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 540pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=720 height=17>https://www.ford-trucks.com/forums/attachment.php?attachmentid=6468&stc=1</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 540pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=720 height=17>Oreilley's - part Zerostart part number 3600008.</TD></TR></TBODY></TABLE>
Old Nov 1, 2008 | 07:44 AM
EOD Guy's Avatar
EOD Guy
You can get the cord on eBay for as chaeap as 21.00
Old Nov 1, 2008 | 11:19 AM
ponyboy123's Avatar
ponyboy123
Cool, that is good news. I'll check ebay first.
Old Nov 1, 2008 | 01:23 PM
bismic's Avatar
bismic
You might try the OReilley's recommendation - some have said it is under $20 there.
Also (according to PowertrokeHD):
Powerstrokeshop.com also sells the Zero Start cord for $16 under part number...
PSM/3600008
I have dealt w/ these guys on a number of purchases and like them.<!-- / message --><!-- sig -->
Old Nov 1, 2008 | 02:55 PM
Lonewolftx's Avatar
Lonewolftx
Wink Looks like this . . .
Here are some pic's from my gallery. It is above the starter on the passengers side of the engine. You have to route the cord to the front right tow hook . . .
Old Nov 1, 2008 | 03:12 PM
bismic's Avatar
bismic
To use the factory install points, you do have to route to the front right tow hook area - but it can be run virtually anywhere that is desired. Many folks route it to the back bumper.
Your pics are very helpful lonewolftx - thanks (they are also in one of the links in my first post).
Old Nov 1, 2008 | 03:25 PM
Lonewolftx's Avatar
Lonewolftx
Wink
U R welcome. Hit me with some rep point . . .
Old Nov 1, 2008 | 05:26 PM
EOD Guy's Avatar
EOD Guy
What's "rep point" ?
Old Nov 1, 2008 | 05:32 PM
ponyboy123's Avatar
ponyboy123
Cool, above the starter on the passenger side. I have a look tomorrow and then start the search for a plug and cable. FTE rules!!!
Old Nov 1, 2008 | 06:08 PM
Lonewolftx's Avatar
Lonewolftx
Red face click the scales on the upper coner
See the scales at the upper right coner of the post? Click it to leave rep point for posters who help you out.
Old Nov 4, 2008 | 10:21 AM
sgthawkusmc's Avatar
sgthawkusmc
Some of us have used a Marinco plug also so you don't have a cord flapping around up there. Makes for a neater more functional install.
Old Nov 4, 2008 | 05:03 PM
EOD Guy's Avatar
EOD Guy
What does the marinco plug look like?
Old Nov 4, 2008 | 06:11 PM
Lonewolftx's Avatar
Lonewolftx
Chk out beachbumcook gallery for pic of it.
Old Nov 4, 2008 | 06:54 PM
rollerstud98's Avatar
rollerstud98
Pony, if you have an international dealer near you, your best bet is to just go to them for it. Quicker then waiting for it to be shipped in from the states and pretty cheap from them, 20 bucks or so when I bought mine from them.
