2006 E350 Front Quarter Panel Removal
Old Oct 31, 2008 | 09:00 PM
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Hello:
What is the sequence to remove the outer sheet metal over the front tire?
(I'm wondering if I have to remove the grill and or headlight/marker light assembly, what to watch out for such as hidden screws, can one person do the R & R?)
I see where the existing antenna wire enters the passenger compartment, and therefore I need to disconnect the coax.
I looked in my Ford shop manual CD and realized that it doesn't cover body work.
I want to install a powered antenna, and it seems the only way to get into the fender space is by taking the fender off.
Also I might have to open up the inner fender to fit the mast tube, so just dropping the flexible wheel well liner might not provide sufficient access.
Thank you,
Sous
All Things Towing
19
Jun 2, 2020 10:17 AM
wjwolfe82
Jul 21, 2017 02:17 PM
Bmcush
May 5, 2017 07:57 PM
rbsev
Apr 27, 2017 03:39 PM
LCAM-01XA
Dec 19, 2012 12:12 AM
