Well it finally happened....
Old Oct 31, 2008 | 07:18 PM
pfogle's Avatar
pfogle
Our beloved 1988 E150/302/AOD finally died. It only has 350ish thousand miles on it. It still runs, but it's loping REAL bad at idle and stall out on occasion. We've tested everything we can think of and can't figure it out. I know it's a computer issue, but no luck there... Having trouble pulling codes, on two computers so I knows that's my fault for not being patient. If anyone has any ideas please let us know.
Old Nov 2, 2008 | 08:46 PM
kynnhoj's Avatar
kynnhoj
Timing chain/ gears? (check by turning crank back and forth and watching rotor for slop)
Throttle position sensor? ( check with volt meter)
IAC valve?
Let us know what you find, John
Old Nov 3, 2008 | 09:01 AM
pfogle's Avatar
pfogle
Timing chain is brand new, TPS checked out fine even re-calibrated it. The IAC is almost new. It was a combination of things. The computer had died AND the EGR valve was stuck open. The new computer didn't help the idle problem so he pulled the vacuum line off the EGR valve (the first thing I told him to do but he didn't listen) and the idle cleared up. Now it runs like a new van.
Old Nov 3, 2008 | 10:01 AM
spikedog's Avatar
spikedog
If anyone could figure it out, it would be you, pfogle.
towsrus
Oct 28, 2011 11:34 AM
92broncoXLT
1978 - 1996 Big Bronco
18
Nov 19, 2010 08:43 AM
BPofMD
Maryland Chapter
Oct 10, 2006 06:43 PM
glw46
Jan 17, 2006 04:54 PM
