'97 E350 6.8 E40D trans. code numbers
Old Nov 3, 2008 | 07:29 PM
stiouxi's Avatar
stiouxi
My E40D AOD transmission in my '97 E350 extended ClubWagon is going out, really harsh vibrating/sound when shifts into 2nd, otherwise still very smooth.
The problem is that the van has 250k miles on it and I've been trying to find a tranny from a wrecking yard.....LOTS of E40D's out there for my model and year but the coding FOLLOWING the E40D is where I'm having problems. The numbers on the aluminum part tag on the drivers side read F7UPGA. I'm guessing that the F7 designates 1997? And the other numbers may be bellhousing? shaft length? other variables depending on the engine/trans bellhousing and/or other differences. I have seen several IDENTICAL vans, 1997-1998's with the 6.8 AOD trans. My question is do I need to get the identical matching post numbers or can I use an E40D from any 6.8L '97-'98 E350? Thanks in advance for ANY help I can get.....
Stuart
Old Nov 3, 2008 | 10:27 PM
Clubwagon's Avatar
Clubwagon
You can use any E4OD from a '97 E series with a 6.8 V10. That tag is a lot code designation.
Kingkong0192
Jan 27, 2017 04:26 AM
97-350
19
Nov 16, 2016 03:12 PM
97Fordf35089f250
Engine Swaps
17
Feb 8, 2016 02:14 PM
jarod17
Testing.....
Jun 28, 2011 10:57 PM
1994F2507.3L
Oct 28, 2010 10:40 PM
