anyone know the difference from an mme2 computer to an mme7?
after putting the aa injectors in my stock ab injector engine, it has been idling funny. ordered a chip from dp tuner and he said that truck would have an mme7 computer. but i pulled it out and its an mme2. should this chip work the same or are the computers different? thanks
Since you had split shots previously after going to singles it going to run a bit differently.
Both those PCM codes are for 97 Cali rigs with an automatic transmission. Your chip just needs to be set up for single shot injectors as opposed to split shots. Just let DP know what you have. They will take care of it.
i had already told them i needed it set for single shot injectors that was the only reason i ordered the chip. its only a 1 position chip just to make it run right. didnt care about added power or features or anything just tired of it idling like junk.
would the difference between an mme2 and mme7 be enough to cause the chip to just not work, or do you think i got a bad chip by chance?
