armrest bolts
Old Nov 2, 2008 | 10:54 AM
Ford_Six's Avatar
Ford_Six
Originally Posted by iggybob44
Mine has 3/8" socket with a logo on the bolt head a capital letter M with a Letter T running up the center leg of the M,and by the way,the holes in the actual armrests,where the bolts go,are kinda ragged,like they have been removed or replaced several times....in the larger sizes,a lot of hardware stores probably have a better selection of hex head bolts than phillips head.....so is it likely that in the 36 plus years that these trucks have been around,its quite likely that most of them have had these bolts/screws replaced with whatever was at hand,and if the correct Ford part was discontinued,it shouldnt be a shock that few are still original
I would think that, given the era of these trucks, that if the screws had been replaced with hardware store stock, you would see quite a few that had flathead screws rather than phillips or hex head. Also, I would think you would find a mix in any given truck, rather than all hex head, or all phillips. If something was a replacement, why would they replace six bolts to make up for loosing one? I only know of a few people that **** to go through that much trouble. I don't think the four trucks I have worked on have had owners like that, especially the ones that didn't show any sign of ever having been opened up.
Old Nov 2, 2008 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/72...the parts catalog only lists that one number, which like all parts sold over the counter is a service part.
Service parts may/may not match the originals.
For example the "squeeze" radiator & heater hose clamps installed at the factory.
Ford didn't even sell them, ditto for the OEM shock absorbers.
The standard equipment non heavy duty shocks installed at the factory weren't even available. Prolly 90% of the vehicles had these as new.
When vehicles are assembled, the cheapest parts are used, which might save the manufacturer five or ten cents per part.
When amortized over a million + vehicles, that adds up to a lot of money.
vacuumbed
Jun 13, 2017 03:06 AM
IHI
Mar 4, 2012 02:19 PM
erniek70
Sep 16, 2010 11:15 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 9, 2008 08:31 AM
cbnewman
Jun 24, 2002 11:15 PM
