center console armrest bracket bolts
Old Jun 21, 2002 | 09:21 PM
cbnewman's Avatar
cbnewman
I own a 93 explorer. My center console's armrest bracket broke (whose hasn't?) and I bought a reinforced replacement bracked. However, I can't locate the four bolts that hold the bracket into the center console. Does anyone have the specs on these bolts or know where I can get replacements?
Thanks,
Ben
Old Jun 22, 2002 | 08:28 PM
ckrichard's Avatar
ckrichard
Post center console armrest bracket bolts
The best way to do this is to move the driver and passenger seats all the way forward. Then pull the lever and let the seats tilt all the way forward too. Look at the very rear of the console and there will be a oval shaped plastic cap. To remove the plastic cap, get a fine tiped screwdriver and pop it out. Inside there will be two bolts to remove on each side. The bolts are a standard size. Take out the old armrest and replace it with the new one. You do not need new bolts, you can reuse the old ones. Just reinstall the bolts and pop the caps back in. Your done.
hope this helps,
chris
Old Jun 22, 2002 | 09:48 PM
cbnewman's Avatar
cbnewman
I should have been more specific. I /lost/ the original bolts. The bracket broke some time ago, so I removed the whole thing to get rid of the jagged plastic piece that I kept impaling myself on. I read a description of how to replace the bracket, and the author referred to them as "8 mm" bolts. Can anyone confirm/expand on this?
Thanks,
Ben
Old Jun 22, 2002 | 10:15 PM
ckrichard's Avatar
ckrichard
First try a junkyard. When i replaced mine i think someone said that the same armrest was made from 91-94 so when you ask if the yard has a explorer make sure to ask for those different years. This weekend i will remove one of these bolts and give you the dimentions. If all else fails call a ford dearlership.
chris
Old Jun 24, 2002 | 01:41 PM
ckrichard's Avatar
ckrichard
The bolt is 8mm. it is 1 in. in length. the shaft is 6 or 7mm thick. it has a 3/4in diameter washer that is 1/16 in. thick.
hope this helps,
chris
Old Jun 24, 2002 | 08:54 PM
cbnewman's Avatar
cbnewman
Thanks for your help. The armrest is installed and secured.
--b
Old Jun 24, 2002 | 11:15 PM
MoonGT's Avatar
MoonGT
Momba2
Escape & Escape Hybrid
Feb 20, 2017 04:06 PM
15expedition
Aug 3, 2016 07:17 PM
Bullcreek
WTB - Parts & other
Jun 2, 2016 10:18 AM
mikereidjr
Aug 19, 2015 07:54 PM
tommyleea
Bronco II
Jan 3, 2011 09:42 AM
