Building a 460
Old Oct 28, 2008 | 04:46 PM
sandbum01's Avatar
sandbum01
Building a 460
I want to build a 460 to put in my 73 F-100 that I will be desert racing. I will be buying a used engine and c6 trans to start with and then completely rebuild both of them. Is there anything to look for when trying to find a donor engine and trans? What kind of power can I get out of one of these? What intake, heads, carb, headers and whatever else is a good combo. Not worried about spending some cash just need a very strong reliable engine. Let me know what you think..
Old Oct 29, 2008 | 10:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 385-series forum.
WELCOME to FTE!
Old Oct 29, 2008 | 05:49 PM
mwvdub's Avatar
mwvdub
do you want to build a stroker or just over bore?
is it sanctioned desert racing?
aluminum heads or iron?
how much money do you want to spend?
there are about 15 head choices, 4 or 5 stroke choices, and various rod choices.
There are people making over 900 hp with modified stock parts safely.
Old Oct 30, 2008 | 12:46 AM
sandbum01's Avatar
sandbum01
460 motor
It is a sanctioned event however it is a fairly open class as far as motor goes I know the only guideline the motor has to follow is it has to be naturally aspirated. I want aluminum heads and don't know what to do as far as bore and stroke. What are the differences in overboaring versus stroking? What block should I be looking for to start with? What kind of price ranges are we looking at here. I am looking to spend what I need for a good motor and still make it reliable. I also don't want to be tuning it all the time. So possibly fuel injected? I don't know?
Old Oct 30, 2008 | 09:15 AM
mwvdub's Avatar
mwvdub
I would look for a D9VE production block. I would have it sonic tested and bore it .060 or .080. Get a forged scat 4.5 stroke crank with 6.7 bbc h-beam rods and a set of diamond pistons. I would get a set of Kaase p-51's or A460 heads, have them cnc ported and top it off with an a460 intake and a dominator. You will have a 557 that make somewhere 800-900 horses.
Old Nov 2, 2008 | 07:07 PM
sandbum01's Avatar
sandbum01
That sounds like what I am looking for. Do you know where I could pick up some of those parts and what kind of price range does all that fall under?
Old Nov 3, 2008 | 01:13 PM
mwvdub's Avatar
mwvdub
call lem evans at bfevansraceparts he will get you what you need.
Last edited by monsterbaby; Nov 3, 2008 at 02:28 PM. Reason: removing links to other web sites.
Old Nov 11, 2008 | 12:05 AM
John Irwin's Avatar
John Irwin
I was wondering if you would put in a good word for Lem...
1969w/460=)
Feb 16, 2013 04:08 AM
jeremy2008
Jun 11, 2009 11:16 AM
On_Final
Apr 26, 2008 09:39 AM
OregonGuy1978
Aug 20, 2007 07:07 AM
nscherneck
Apr 10, 2007 04:57 AM
