plug in
Old Oct 28, 2008 | 09:16 AM
JoeKan's Avatar
JoeKan
plug in
Good morning,
I plugged my 2000 X in this morning due to the cold weather and sparks shot out through the plug. I quickly unplugged it and found a nick in the wire and I taped it with electrical tape and plugged it back in. My question is how do I know it is working properly and I didn't burn anything up? Is there way that I can tell if the glow plugs are being heated?
Thank you for your input,
Joe
Old Oct 28, 2008 | 09:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The glow plugs are not heated when you plug it in. The block heater is what you are plugging in and it heats the coolant in the block. You could look at your electric meter when it's plugged in or not, it should spin faster with it plugged in. You could also touch the engine block after it's been plugged in for at least a couple hours. If it is warmer than everything else the heater is working.
Old Oct 28, 2008 | 09:46 AM
JoeKan's Avatar
JoeKan
Thanks Mark,
If something got burned up, what would it be?
Old Oct 28, 2008 | 11:53 AM
JoeKan's Avatar
JoeKan
I just check the heater block and it is not warm. What do you think my next move should be?
Thanks.
Old Oct 28, 2008 | 12:38 PM
ReAX's Avatar
ReAX
Do you have a DMM? The heater is probably like a water heater and should have a very high resistance, when you pass enough current through it, it gets very hot. Hopefully you should read a resistance and not infinite resistance. If you read a low resistance then you have another short or the element is probably shot.
Drjoe642
May 8, 2016 09:27 AM
Lucille1986
Apr 2, 2013 11:08 AM
joe f350
13
Mar 2, 2011 04:33 PM
SC74
Feb 4, 2011 04:46 PM
Joe
Oct 27, 1999 08:24 PM
