Sponsored by: Real Truck
Unknown wire near OBD II Plug
Old Feb 4, 2011 | 11:59 AM
SC74's Avatar
SC74
I was looking under my dash to see how the PO had wired the Prodigy brake controller and noticed several loose wires. They are taped (with factory silver tape) to the loom that feeds the OBD II. There is a white, red, blue, black, and teal colored wire - all dead ending there with no sort of tape or plug on them. I also noticed a black, red, blue, and white wire under the hood on the driver side firewall that are not hooked to anything. I haven't had a chance to test yet to see if these are the same wires, but what are these for?
My guess is to hardwire in a brake controller if you can't find a plug to plug into the factory harness?
Old Feb 4, 2011 | 12:52 PM
dchamberlain's Avatar
dchamberlain
The 4 wires that are both under the dash and in the engine compartment are called pass-through wires. They just pass through the firewall and are there for whatever you might want to use them for.
The other wire might depend on what year truck you have, but if it is a 14 gauge wire attached to the OBD-II bundle, it is probably the accessory power wire. It is there for whatever you might want powered, is fused 10 amp and should be on in Run and Acc.
Old Feb 4, 2011 | 01:17 PM
SC74's Avatar
SC74
Perfect! Thank you for the quick response. It is a '99 F350.
Old Feb 4, 2011 | 02:54 PM
alwayschooseford's Avatar
alwayschooseford
Wow. I have never seen the pass through wires. I wonder if '01 has them or if mine have already been used. But that is a cool idea!
Old Feb 4, 2011 | 03:10 PM
brd7666's Avatar
brd7666
Your 01 has the same wires. The other end of the passthrough wires comes out of the firewall behind the brake cylinder. The other one has power going to it when the ignition is on.
Old Feb 4, 2011 | 04:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
My '01 has them...
gradyc
Jun 8, 2014 10:10 PM
7mmstw
All Things Towing
Oct 24, 2012 05:55 PM
Frankievespa
Apr 11, 2011 09:56 PM
Junkman of Delaware
Jan 7, 2011 01:18 PM
dixie217
All Things Towing
May 12, 2009 08:44 PM
