drian pan plug
Old Mar 2, 2011 | 01:13 PM
joe f350's Avatar
joe f350
drian pan plug
when i wet to change my oil i use a wrenck pop out the plug and when i put it back in it just keep spining it was flush i used a wrench and i was carfull not to over tighting it if i strip it do i have to replace the drina pian it donst leack out i croved it in duck tape so it dosnt fall out are there any easy fixes for this im kind scard to drive the truck right know
Old Mar 2, 2011 | 01:16 PM
juni88126's Avatar
juni88126
You should be able to get an oversized plug at your local parts store
Old Mar 2, 2011 | 01:47 PM
GHeTTo JOe's Avatar
GHeTTo JOe
im guessing if you look at the plug the threads are hashed. sbhould be easy fix just replace the plug with new original. if the threads on the plug are good then yes you will need to rethread the pan and oversize plug
Old Mar 2, 2011 | 02:36 PM
snaponprofile's Avatar
snaponprofile
And if he just changed his oil, he will lose some of it once he starts inspecting the plug. Hope it wasn't expensive oil joe.
Old Mar 2, 2011 | 02:39 PM
joe f350's Avatar
joe f350
oh it was rotela 5w 40 i put some rtb on it them some duck tape
Old Mar 2, 2011 | 02:46 PM
wreckinball's Avatar
wreckinball
no just get a bolt with smaller size threads and put a washer on it, then smear it with the ultra grey or similar silicone. let it cure mostly, then pull the old one and slam this one in with the same duct tape idea and it will hold long enough to get the job done. Or just drain it into a clean container. container might be easier! lol
Old Mar 2, 2011 | 02:49 PM
snaponprofile
Yeah, a lot easier, lol - just get a 5 gallon bucket.
Old Mar 2, 2011 | 02:51 PM
wreckinball
Dont drive it with the duct tape, itll melt off and cause a gulf of mexico. lol
Old Mar 2, 2011 | 02:56 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Just put a bullet in it...........................it's done.......
Old Mar 2, 2011 | 03:00 PM
joe f350's Avatar
joe f350
i ant gona old yeller my truck dodge
Old Mar 2, 2011 | 03:09 PM
Dodge/Cummins
That was a good one, you got me there!
Old Mar 2, 2011 | 03:44 PM
1994F2507.3L's Avatar
1994F2507.3L
ive never seen the inside of one of these pans but on my old 351 it had a triangle shaped "nut" with the corners spot welded to the bottom of the pan the welds broke loose and the plug would just spin up in there and could never get it tight so i put one of those special plugs you can get from oriellys worked just fine until the ol girl caught fire (arson..... literally)
Dorman 65109 - Oil Drain Plug | O'Reilly Auto Parts
Old Mar 2, 2011 | 04:10 PM
snaponprofile
There ya go joe!
Old Mar 2, 2011 | 04:33 PM
oreocreaming's Avatar
oreocreaming
weld the nut to the bottom of the pan joe. by the time you get 3-5k miles on it then you can just bring the truck here, we'll unbolt the engine, drop the pan and put in one of my extras. new gasket so it will stop any leaks that you have anyways.
pesposito
Jul 29, 2012 12:57 PM
Tom Hairhoger
May 2, 2010 07:01 PM
CountryDeisel
Jan 6, 2010 11:17 AM
scatgo
Dec 23, 2009 04:45 AM
