Statement of Intent
Old Oct 30, 2008 | 01:11 PM
  #31
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BradyCouchman
ummm depending on how long they have been out of the car they might not work...bill (ND) made a post about it somewhere.....
If any port where a hose attached, or where two parts come together: dryer tank attached to condenser for example, is left open to the elements for a short length of time, the system is ruined.
Once air gets inside (especially if moist), it is imperative the system is evacuated ASAP.
Otherwise, you can kiss your condenser, compressor, expansion valve and dryer tank good bye.
Example: Peeps go to a wrecking yard searching for a compressor, find one, remove the hoses from the ports, take the compressor home, fail to tape up the ports.
3 weeks later, they install the puppy and wonder why the hell the shaft will no longer turn, or the compressor growls like a enraged bear.
The compressor is HISTORY!
Do not buy any A/C parts if the ports are uncapped, or are not taped over (= as new, this is the way some parts come in packages), or are otherwise left open to the elements.
Old Oct 30, 2008 | 01:25 PM
  #32
67nukeford's Avatar
67nukeford
Veteran: Navy
Hey, thanks for the heads up on that Bill!
Old Oct 30, 2008 | 02:59 PM
  #33
garbz2's Avatar
garbz2
If you think 400 is expensive for a custom bell to adapt to transmissions that never were intended to be installed then you are in the wrong hobby......
BTW a TKO will set you back 2K
There is no cheep way...
Garbz
Old Oct 30, 2008 | 09:12 PM
  #34
SuperBeaner's Avatar
SuperBeaner
On a lighter note, where would the best place be to look for an A/C? aftermarket is ok, being that this is going to be a restomod truck. Im hellbent on installing it, i know its hard, i know its expensive, but im gonna do it.
1999-F150
1997 - 2003 F150
Jul 13, 2017 12:45 PM
DDT11
Jun 5, 2017 05:39 PM
superdave02f552
Aug 6, 2014 12:03 PM
FUJINAMI1293
6.7L Power Stroke Diesel
18
Jan 4, 2013 01:18 PM
Allan
Sep 20, 1999 08:48 PM
