C4 Trouble
Old Oct 26, 2008 | 01:55 PM
302 F-150's Avatar
302 F-150
C4 Trouble
Hello, I have recently picked up a 77 f-100 two wheel drive flareside with a 302 and c4. The problem is I have to set the idle way high (1200-1500 rpm) with the transmission in park in order to get it to idle in drive. Any suggestions as to what is happening. Any chance it could be something simple like the vacuum modulator or is it something internal. Thanks, Al.
Old Oct 26, 2008 | 05:15 PM
stuart1's Avatar
stuart1
Give the engine a tune up!
Old Oct 26, 2008 | 07:35 PM
jk080's Avatar
jk080
Transmission Rebuilder
yea I agree its a engine problem
Old Oct 26, 2008 | 07:44 PM
302 F-150's Avatar
302 F-150
Well, I changed the plugs, wires, cap, and rotor and it helped some. I'll try rebuilding the carb and check for vacuum leaks and see if that helps. Thanks for your help
Old Oct 27, 2008 | 08:23 AM
Lazy K's Avatar
Lazy K
Check your ign. timing.
Old Oct 27, 2008 | 09:34 PM
302 F-150's Avatar
302 F-150
Well, I checked and adjusted the timing and now it idles beautifully in both park and drive. Thanks a lot for your help!
glasstruck
May 28, 2007 01:46 PM
Msp541
Dec 25, 2006 11:21 AM
boond0cksaint
May 17, 2004 04:18 AM
BigRebel
Jan 9, 2000 04:49 PM
