idle setting ?
Old May 13, 2004 | 09:16 PM
boond0cksaint's Avatar
boond0cksaint
idle setting ?
what is the idle setting for an 88 f150 w/ 302 efi, c-6. on my 70 1/2 falcon i have it at 1000 in park and 850 in drive(idle). timed the motor to 10' btc and try to bump up the idle, when i get it to 1000, it wants to surge up and down, and when i put it in drive the idle drops way down then jumps up to about 800, set it back to where i had it and it runs perfect. old settings are at 900 rpms in drive and 650 - 700 rpms in drive. now i adjusted the tps to read 0.9v on the old idle settings, would i have to reset the tps settings if i adjust the idle? have not got a c.e.l for the tps, just 02 and egr but im going carb in a month anyway, just want to get my idle right. thanks in advance for any response.
Old May 14, 2004 | 11:20 AM
EPNCSU2006's Avatar
EPNCSU2006
650 - 700 in drive sounds just right. I'd leave it there because any higher and the computer gets confused - it thinks you are in the throttle, and so it won't idle.
Old May 16, 2004 | 07:42 PM
Fully_Loaded's Avatar
Fully_Loaded
The computer automatically sets the idle. 650-700 is a healthy idle in drive. It should be about the same in park also
Old May 17, 2004 | 04:18 AM
boond0cksaint
when im in idle it stays between 700-750, when i put it in park it jumps up to 1500 then settles at 900. thanks for the replies. ill leave it where its at.
LSO1123
Dec 22, 2015 01:29 AM
Turtlebeach
Nov 5, 2015 09:18 PM
truelygr8
Feb 9, 2014 12:32 PM
timbersteel
Mar 13, 2011 02:13 PM
gmk035
Mar 14, 2010 06:09 PM
