Electrical issues
Old Oct 25, 2008 | 09:09 AM
mongoosekeith's Avatar
mongoosekeith
Unhappy Electrical issues
ok the head light and park light switch went out in my truck, now i have no brake lights or turn signals, are all lights ran through the switch or do i have some other wiring issues also?
Old Oct 25, 2008 | 10:21 AM
Redcat Diesel's Avatar
Redcat Diesel
The turn signals and stop lights share the same fuse. I would check to see if it's blown. I'd suggest removing the headlight switch and looking closely at the connector. These switches tend to overheat which damages both the switch and the connector. Overloading them with non factory light just adds to the problem.
I have studied the wiring diagrams for these trucks and came to the conclusion that most of them should have burned to the ground before the factory warranty expired.
Old Oct 25, 2008 | 10:24 AM
mongoosekeith
ok thanks man. can i just put a few toggles on the wires until i get me a switch or do they have them at Oreily??
Old Oct 25, 2008 | 10:31 AM
Redcat Diesel
I've never dealt with O'Riellys since we don't have any around here but I'd give them a try. Headlight switches are definitely still available thru most parts stores.
Old Oct 25, 2008 | 10:34 AM
mongoosekeith
ok i will look around.
I have heard that they go out often is this true?
Old Oct 25, 2008 | 10:56 AM
Redcat Diesel
Yes. When I used to run a bumpside truck as a daily driver I kept a new headlight switch at home. It was like buying oil by the case. You're gonna use it so why not stock it.
Old Oct 25, 2008 | 12:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ11654A .. Headlamp Switch (Motorcraft SW539) / Obsolete
Fits: 1965/72 F100/350. Autoparts stores can cross the Motorcraft number over to the brands they sell.
There is another switch listed for 1965/72's, but it was only used on Open Drive-Away Cab & Windshield, or Cab & Cowl models.
Redcat Diesel: ALL the 1968/69 cars, 1968/69 F100/350's, 1970 F100/350's, 1969/70 Econolines (both 1970's before serial # G90,001) used an ignition switch that shorted out internally and caught fire.
1000's of
vehicles were destroyed by fire, caused by these faulty switches. Most of the vehicles were new, or nearly new.
One local dealership burned to the ground in 1969. The cause was linked to a new LTD's faulty switch.
Ford came out with a new switch (D1AZ11572C ~ Motorcraft SW1054) that came with a pigtailed wire plug. This replacement switch is still available from Ford.
While most of the faulty switches were replaced for free back then via a Ford "campaign" as there was no recall, because vehicles weren't recalled in those days....
One never knows if some of those faulty switches are still around...in someone's vehicle.
One member here had an issue with one of these switches, so I've typed this same info before.
Old Oct 26, 2008 | 08:03 PM
mongoosekeith
Thank you! I appreciate the help guys
stownsen914
Apr 23, 2014 08:44 AM
ten.mile
Dec 11, 2012 05:56 PM
Aune163rd
Modular V10 (6.8l)
Jun 2, 2012 03:28 AM
AlexD
1983 - 2012 Ranger & B-Series
Feb 5, 2012 10:01 AM
charon61285
Sep 20, 2009 11:32 PM
