Tko
Old Oct 23, 2008 | 01:10 AM
Scifi266's Avatar
Scifi266
Tko
I've been researching Some of the 5 speed trannys and was wondering what you guys thought about them?
I'm gonna save up the money get one if they are worth it.
If I get one will the Bellhousing off my T-18 work? or would I need a new one?
I've got a 390 out of a 69 cougar in a 66' F250
Thanks!
Old Oct 23, 2008 | 06:32 AM
jowilker's Avatar
jowilker
There are no modern transmissions that will bolt up to a 390. Any will have to be run through a $600.00 adapter.
Don't let that statement stop you from looking though, one never knows what he can run up on and make work.
There is one poster that recommends a 5 spd. Clark from a mid size truck that will bolt up, but I have never looked into it.
John
Old Oct 23, 2008 | 02:00 PM
85e150's Avatar
85e150
TKO and the like will bolt up to an FE bell housing. You can get the correct length input shaft, or an $150 spacer to make the install.
Integral bell transmissions like the ZF won't bolt up, and since you can adapt the NV 4500 for far less, why would you pay $650 for an adaptor for of them?
Regarding the TKO to FE, check here. They answered my email very quickly.
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - Swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
AubreyA3
Aug 16, 2016 07:38 PM
Terry SD
Nov 2, 2012 12:51 PM
MagKarl
Nov 7, 2007 09:53 AM
51dueller
Aug 31, 2006 03:04 PM
crawlfish
Exhaust Systems
Mar 22, 2006 04:36 AM
