Vibration over 70 mph
Old Oct 22, 2008 | 09:34 PM
Night Bird's Avatar
Night Bird
I am having a weird vibration over 70 mph, really starts kicking in over 80 mph and up. It is enought to make the passenger seat shake, and the dash start to vibrate as well. It has done it for as long as I have had it from when I got it a 50k on the clock stock. I can not rember if it did it with stock wheels cause I changed them the next day or so. I have eagle alloy series 058 16" wheels, with nitto terra grapplers on them 305/70/16. I just put a super lift 3" kit on the truck and that did not do a thing for it. Any ideas.
thanks
Old Oct 22, 2008 | 10:00 PM
6686L's Avatar
6686L
Recommend you go to a tire shop with GOOD balancing equipment. Their equipment will determine if your wheels and/or tires are out-of-round.
With balance and "round" issues out of the way, next step is the drive-shaft and other rotating parts. I have seen cases of balance-weights, (spot-welded, typically) coming off of torque convertors.
Have fun.
Old Oct 22, 2008 | 10:12 PM
ramtime's Avatar
ramtime
I would crawl underneath it and check out the u-joints and make sure they are in good condition. It's amazing how a little bit of movement gets magnified with more revolutions.
Old Oct 23, 2008 | 07:33 PM
Night Bird's Avatar
Night Bird
Thanks guys, I have done the blance thing and it still dose it, I am starting to belive drive shaft might be cause. My Grandfather has a 2000 super duty and he had to replace drive shaft for similar reasons.
Old Oct 23, 2008 | 07:57 PM
VaSheriff's Avatar
VaSheriff
I honestly don't know, but where in America is the speed limit over 70?
Combined with the fact that going 80+ mph in an Excursion is a major disaster just waiting to happen.
Old Oct 23, 2008 | 08:07 PM
X-70STANG-F150's Avatar
X-70STANG-F150
one of our GMC work trucks need new U-joints around 50k too. We were told by the shop that the drive shaft lined up between the trans and the rear end so good that there is too little movement in the bearings. funny though, we've got about 200k out of the replacement set ?!?
Old Oct 23, 2008 | 08:37 PM
chapfr's Avatar
chapfr
I have approx. same lift with 35"Nitto tires , same exact issues , bought new Micky Thompson tires , problem gone
Old Oct 24, 2008 | 02:44 AM
6686L's Avatar
6686L
Good question and good point about high speeds.
First <> as to speed limits - out here in the west, several states have speed limits of 75. Since many people THINK there is some "cushion" before law enforcement will "write -you- up", people more often than not cruise at 80 or more.
Secondly <> as to 80+ speeds - I couldn't agree more. Our EX's have a VERY high roll-center, coupled with primitive ( meaning pre mid 1930's type) suspensions. VERY bad combination for high speed driving. In my view, 75 mph is WAY too fast except under the most ideal conditions.
Old Oct 24, 2008 | 06:47 AM
jackassjeeper97's Avatar
jackassjeeper97
I have the same problem at 70 and have changed wheels to factory put 2 sets of michelins and they are road force balanced. Still same problem I guess next I will pull drive shaft and have it checked for balance and put new joints in it since it is out.
Old Oct 24, 2008 | 06:59 AM
jackassjeeper97
Also in Idaho,Montana,Nebraska,Nevada,New Mexico, North Dakota,Oklahoma,South Dakota,Wyoming,and Utah all have interstate that one point or another have 75 mph speed limits there maybe others and Utah can post a speed limit over 75 on I-15 between milepost 222 and 64 if warranted by a safety study and a consideration of roadway geometry and population density. Only know this because it was a debate on another site and someone posted this from the Insurance Institute for Highway Safety.If I was smarter I would be able post link.
Old Oct 24, 2008 | 08:41 AM
Wilson & Co's Avatar
Wilson & Co
Texas on 10 I believe, all the way to NM the speed limit IS indeed 80mph.
Old Oct 24, 2008 | 10:43 AM
Night Bird's Avatar
Night Bird
Thanks guys. I appreciate the info, I will see what I can come up with bout those U joints.
Old Oct 24, 2008 | 04:04 PM
VaSheriff's Avatar
VaSheriff
If the speed limit is 80 mph, people will feel comfortable in going 85 and 90 mph without risking a speeding ticket.
Won't catch me driving an Excursion 90 mph for any extended distance.
Old Oct 24, 2008 | 08:12 PM
UrbanXX's Avatar
UrbanXX
Mine has barely been over 70 mph. I just see no reason to run it over 70 mph.
Although my Excursion is in excellent condition and needs nothing, I feel as though it is at the handeling saturation point at any thing over 70 mph.
Old Oct 25, 2008 | 12:05 PM
aortizexcursion's Avatar
aortizexcursion
Yes, rural highways out in West Texas do have 80 mph speed limits.
bielaf
Oct 14, 2015 08:36 PM
annaleigh
Jun 15, 2015 02:31 AM
DanielT28
Aug 12, 2014 04:36 PM
pittdog1977
Jun 8, 2014 09:56 AM
xd2200
May 24, 2014 10:30 PM
